Ford 7.3 gas chassis dyno
EFI
Masshole central
5.Br0
....or you can get a 14 year old LS7 and do a cam swap and make 600.
I don’t think this is progress.
It's not progress because it wasn't mean to be progress to begin with. They designed this engine to make the power and torque as needed in a run of the mill (albeit expensive) work truck not an exotic aluminum high revving sports car.
engineermike
La
2018 GTPP A10
While I agree with you, there are some that wholeheartedly believe this motor is, in fact, ford’s way of sneaking some sort of race engine-in-disguise out to the public.
engineermike
La
2018 GTPP A10
From what I understand those LS7s are ticking time bombs. Not enough guide for the exhaust valves, or something? You're probably going to want to fix that issue. And if you are adding a cam with greater lift than stock, beware that not all the fixes will take care of the issues with valves dropping and destroying the engine.
Ok so 14 years later, ford builds an engine with 75 hp less from 20 more cid. Maybe they’ll be more reliable or maybe not, only time will tell. My point is that saying this new ford engine has great potential, all you have to do is change the compression displacement cam porting tune intake manifold and exhaust and boom! 600 hp is a bit ridiculous. The LS7 did it a long time ago with way less parts required.
EFI
Masshole central
5.Br0
I can definitely see them doing something like that, however in this day and age of fancy engines it's hard to see an iron block pushrod engine being this "race engine" in disguise. I could believe the R Voodoo engine as being this.
Hack
Minneapolis
Mustang, GR86
I don't know why you think a truck engine and a Corvette engine should be the same. It's obvious that Ford knows how to build engines with 100 hp per liter naturally aspirated as they have done that. The LS7 doesn't make much HP for being 7 liters.
engineermike
La
2018 GTPP A10
I don't know why you think a truck engine and a Corvette engine should be the same....
I don’t! That’s my point, actually. The 7.3 isn’t a performance engine.
I Bleed Ford Blue
North East OHIO
2017 grabber blue GT PP1 convertible
Correct, it's not, but given the right parts, it could be. And that's all I was trying to say.
Dusten
Conway, Wa
Dusten
2018 Ford Mustang, 2001 Ford Lightning, 1968 Ford Mustang
The 7.3 engine is so new. I can hardly wait for two more years to see what the 7.3 engine will be like. Be fun to see a race version in a Fox Mustang.
so tell us... instead of trying to sound cool
Dusten
Conway, Wa
Dusten
what kind of power are gm's truck engines making? Because thats the real comparison.
engineermike
La
2018 GTPP A10
I agree. Truck motor vs truck motor the 7.3 looks pretty good. But a race motor it is not...
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
Did someone say '7.3 in a Foxbody'?
I Bleed Ford Blue
North East OHIO
Gm also brought out a new gas truck engine for 2020 it's basically a larger displacement LS, it's a 6.6L and it makes 401 hp and 464 tq, slightly less than the 7.3 from ford.
Shifting_Gears
South Florida
That’s not possible!11
It’ll never work because it’s just a truck motor! That’s fake news and camera magic!
Haha. Cool to see the first (I’m guessing) confirmed swap.
engineermike
La
2018 GTPP A10
Who said it wasn’t possible?
I suppose installing any ole truck motor into a 2700 lb car makes it an instant race motor.
Hack
Minneapolis
Mustang, GR86
I wonder how long it will be before we see some aftermarket heads and intake for the 7.3.
19 - Diode Dynamics - 1
