FI System with least Heat Soak Issues
DougS550
Fishers, Indiana
Doug
Hey. Just wanted to get the most current forum members opinions on which forced induction system, Manufacturing has the least Heat Soak Issues for hard street driving. Thank you for your help.
DougS550
DougS550
Fishers, Indiana
Doug
Centrifugals will often have the best average IATs unless pullied very aggressively. Temps come down pretty quickly after a pull.
Thank you for your reply. I will go with a system that has reliable HP output again, and again and again. I don't want a system which after some hard street driving have to stop, smoke a couple of packs cigarettes before I can go back out and drive hard again. And I don't even smoke
Keo_S550
Missouri
Daniel
2017 S550 GT Premium Ignot Silver
Definitely a centri would work best.
DougS550
DougS550
Fishers, Indiana
Doug
I just never knew with all of the advancements in FI, that no one can make a system which controlla the dreaded HP killing heat Soak
NightmareMoon
2016 Mustang GT PP w/ Voodoo
The laws of thermodynamics haven't changed (last time I checked)
SolarFlare
S. Fla
2015 CO GT
Maybe you will have some luck if you have a big whipple, big pulley, big heat exchanger with fans and a large battery location or trunk tank. Likely won’t run as cool as a centri but should hold very high temps at bay.
schmeky
West Monroe Louisiana
David
2018 Mustang GT, 2024 Mustang GT
My Pro-Charger will cruise at 2 - 3 degrees above ambient.
When idling for long periods in a drive thru (for instance), the biggest delta is only 32 degrees. For example, 77 degree ambient, IAT will hit 109, when the factory cooling fans kick on, it will drop quickly to 105 - 106.
Get back on the road and it will drop back to 2 - 3 degrees above ambient in just a minute or 2.
Simply outstanding.
DougS550
DougS550
Fishers, Indiana
Doug
Thanks. Do you know anyone running something like the Killer Chiller, I think that's what it is called?
SolarFlare
S. Fla
2015 CO GT
I do not. I just think at that point you’re trying too hard
Zrussian13
Phoenix
My TT set up has been great for heat soak to this point. Iats are 2-3° above while cruising, rush hour and drive thrus haven't crept more than 16° above. Just did a road trip and CHTs ran around 210° or less. Went up to 216° pulling the mountains but right back down. Right after installing the kit I went out for an hour long hard drive and CHTs reached 232°! That was after a lot of pulls and no noticeable loss in power plus it dropped quick once I got off the fun pedal. For reference, outside temps around here have passed the 100° mark already.
Whitedevil95
Temecula, CA
J.P.
2022 Mach 1 HP
When you centri guys are posting about your IATs are you actually taking IAT2s at the Intake manifold?
DougS550
DougS550
Fishers, Indiana
Doug
Thank you for the Great Info on FI street driving conditions. Which system are you running?, Any regrets or what ifs? Something you wish you would have done differently?
Thank you
RockStang
AA county MD
Joe
2016 GT Whippled
These new FI systems don't suffer from "heatsoak" the way people used to think of it. Sure, if you're sitting still, the IATs will go up on any system. Once you start moving, temps drop pretty quickly. I don't see your location but unless your area has consistent 90+ temps, I wouldn't use Heatsoak to determine what system you put on your car. A water based cooling system has the potential to be more temp friendly. I have a friend with a Procharger kit and his IATs are consistently higher than mine on the Whipple with big heat exchanger. I do have a trunk mounted water tank though. My IATS actually go down during a pull where his go up as his boost increases. I also had to run water lines under the car and do a lot more work than he did.
Decide if you want a simple or complex system. A centri kit is far easier to install, less maintenance and will still get you where you want to be power wise. I love my Whipple but I have chased many an issue with belt alignment and you just have many more points of issues/leaks. Not to mention all the added expense of 10-rib upgrade.
SolarFlare
S. Fla
2015 CO GT
Yea my sensor is in the manifold
