Factory OEM Camber Plates vs Aftermarket?
CptSumTingWong
TX
2020 GT350
I have a set of the OEM camber plates that never got installed on my car. I'm about to get this installed but was wondering if there's any reason not to install the OEM camber plates and get some aftermarket camber plates instead?
Seems there's a lot of info on the MM, Steeda, and Vorshlag camber plates but not much on the factory ones. Would rather not spend the extra money if there's no reason to, but if the factory ones are significantly worse than any of the aftermarket options then I'd rather go aftermarket and only do the labor once.
Epiphany
Global
I like to disassemble things.
If you are likely to never need to adjust camber once set and are just looking for additional camber, the factory plates may work well for you (just know that the adjustment window is somewhat limited with them). If you track and are likely to be changing alignment settings fairly frequently, then by all means, go aftermarket such as Vorshlag.
Does this thread help you out? It was one I had put up a while back;
Ford CC Plates (KR3J-3D122-AA) / M-3050-A
https://www.mustang6g.com/forums/threads/ford-cc-plates-kr3j-3d122-aa-m-3050-a.164569/#post-3349151
and go to Post #3 in the above link which has more info/anther hyperlink.
CptSumTingWong
TX
2020 GT350
It's a weekend and track car (maybe 4 track days a year?), so not much daily wear. I was thinking of just setting it at an "aggressive street" or "mild track" setting and leaving it be and hoping it's not too hard on the tires.
I was thinking something like
-1.9 camber and .08 toe in
CptSumTingWong
TX
2020 GT350
Any concern voiding warranty/extended warranty with non factory plates?
CptSumTingWong
TX
2020 GT350
What warranty would it void. Ford isn’t going to cover tire wear from adjusting for the track any way.
Blown shocks or bushings etc that they might try to blame on the aftermarket part or excessive camber?
luc
CA
2017 GT with PP
What wear tires is toe, not camber
You can get about 3* of negative camber with the Ford plate. Go for 0 toe
Epiphany
Global
Given the above I'd use the factory adjustable plates. You'll only fight with them one time and be done. That's where the Vorshlag plates shine, ease of use. They also have a wider range of adjustment but it sounds like you'll get by just fine with the factory plates as your numbers are mild enough.
svttim
Wisconsin
2019 GT350R
Ive used both. I got -25 with the factory plates. I wanted more. I use the Vorschlag and still only get -25 because of the shock tower. I will be fixing that. Aside from that I like that I canset it back to a street alignment at the track.
svttim
Wisconsin
2019 GT350R
Dang, -25?!?! I bet that shit looks way crazy! Hard to picture this on a 350, but you do you bro. Probably handles great tho!
Always has to be one guy :cwl:
fpa1974
GA
'19 GT350R
Yep. I was going to say the same. If you do not want to mess with the shock tower opening the factory plates give you just as much camber as the expensive Vorshlag ones (around 2.5). OEM ones do not have caster adjustment (but if you exercise that on Vorshlag you lose camber range). MM ones used to change ride height (not sure if they ever fixed that).
thornclaw
northbrook, il
2015 mustang gt
people that say camber doesnt cause abnormal tire wear havent seen this man’s car
