OEM Camber Plates Install @ Dealer
TMully06
Batesville, IN
Tim
2019 GT350R, 2017 F80 M3, 2020 Lincoln Navigator Black Label
I am suppose to pick up my new 19' GT350R tomorrow at the dealer (out of state... so a long commute) and I got a call saying that they did not have the right tool to install the camber plates and would have to order it (saying it was a special tool). It is a small dealer (sells trucks to farmers) in the mid-west...
Two questions:
  • Is this possible?... not a mechanic but it looks like just standard socket bolts?
  • If I elect to get the car and have them installed at a dealer I trust... what would this cost?
Thanks for the feedback.
Niz55
Us
17 GT350
Yeah if they need a "special" tool, you better off installing it somewhere else.
You looking at $300-$350 with alignment.
Niz55
Us
17 GT350
I use an impact to tighten the bolt.
Cammer
Portland, OR
2016 Shelby GT350, 2001 F-150 Lightning
I did too, but when I obtained one of these tools, I found out that I wasn’t achieving the factory torque spec on the nut.
Brian
MikeR397
MI
Ford GT350R & Raptor; Ferrari 360, Aston Martin Vantage, Porsche Cayenne GTS, Jaguar XFR
Correct, I did the camber plate install myself and likewise didn’t have the tool to do the 70lbs iirc steeda says for the strut nut. I put tape over the nuts and had ford torque it for me when I had it aligned, no big deal, just verify they actually did it! Wasn’t going to buy a pricey tool for one time use
MikeR397
MI
Try it manually, at like 50lbs it just spins freely continuously and you are under torqued. You should not use an impact for something requiring specs and importance like this.
TMully06
TMully06
Batesville, IN
Tim
Thank you everyone for the replies - I went ahead and picked it up and will have the plates installed at a later date before I track it for the first time. They did not have the tool which @Cammer referenced. Will post some pictures of KR277 soon!
Tim
jameskhana
Dallas, TX
2017 GT Base
@TMully06 Did you pick up the OEM camber plates with your GT350R as well, and if so can you please share any part numbers that are on them?
GT30fan
Livonia, MI 48150
Andy
2015 F350 4x4, 2019 GT350 , work trucks
I know this is an old thread, but have any of you installed your own camber plate? How much of a PITA was it? thx
Jbraun2828
Mi
Jason
2019 gt350
I just installed Steeda plates a week ago. You need a spring compressor but other than that everything is pretty straight forward. I used an impact on the top nut. It took me a good couple hours. Haven’t got an alignment done yet
GT30fan
Livonia, MI 48150
Andy
Your in Michigan? Do any side work (grin)?
Jbraun2828
Mi
Jason
2019 gt350
Ha, I barely have enough time to do my own stuff. Honestly it’s not a bad job. Take the caliper and rotor off, 2 bolts through the knuckle, 1 bolt from vertical link, 2-3 plugs on the shock and take the 3 nuts off the top and that’s it.
