Steeda vs Ford Camber Plates
matthewr87
2018 GT350
I couldn't decide whether to spend $300 on FP, $330 on Steeda or $500 on Borschlaaaag so I spent $1200 on SPL adjustable front LCAs and tension arms instead :giggle:
tj@steeda
Timothy
For those consumers who are interested in seeing the difference between Camber Plates & Bolts:
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Does anyone make a camber plate with a real bearing in it? Like a coil over?
WD Pro
United Kingdom
Lime GT
K4fxd
NKY
or have I misunderstood ?
Yep.
A bearing like when the strut assembly is bolted together and you can spin the top plate.
JAJ
Vancouver BC
2016 GT350 Track Pack
They all have real bearings in them, otherwise you couldn't steer the car. Products like the Steeda plates and OEM re-use the factory bearing and upper spring mount. Products like Vorshlag provide a replacement bearing and upper spring mount. They all do the same thing. The argument as to which is better isn't something I'm interested in. I have a set of Vorshlags on the shelf that I took off to install the Steeda's. For my purposes the Steeda's have been very successful.
Quik5oh
CT
Mark
2022 Mach 1; 2022 GT500; 88 LX 5.0; 86 GT
Anyone try/have the Maximum Motorsports C/C plates for the S550?
I have all MM parts on my Foxbodies and they are second to none. I've tried all other brands over the past 25 years, MM FTW.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Not personally but if you do a search you’ll find threads. Some reports of people not getting as much camber as they wanted (IIRC). MM parts arent as popular on the S550. Not sure if theres a good reason other than they just dont put as much effort into supporting this platform
For aftermarket plates I can vouch for the Steeda units - they do the job with no drama, and Vorshlag are the gold standard if you just need to pay a lot.
RKRZ
Toronto, Ontario, Canada
2020 GT MT82 PP1 301A AE MR
Let me know if I can help assist with the Steeda units - i'll send you a discount code to use for consideration.
Best Regards,
TJ
Can I still take you up on that? Was hoping for a discount with the black friday sale but there is none.
