Engine oil?
1Slow5PointOh
Georgia
Gerald
2015 Mustang GT premium PP
I've always been a penzoil ultra platinum fan. I own a gen 2 and stick with the recommended 5w20 and a ford filter.
Come spring time my car will see some major changes and this thread has me reconsidering what weight to use. It'll be a Gen 2 TT daily driven car.
I live in Florida/Georgia so the car will be pretty hot at times. I'm thinking 5w30, maybe 5w40.
Also, has anyone noticed any differences in blowby or catch can amount by running a different viscosity?
SheepDog
Colorado
Dax
No one using Schaeffer's ?
Barrel
Hoonigan
Cars and Trucks
SSG 5.0
SSG 5.0
2017 Mustang GT
moffetts
San Mateo CA
Black Whippled 2015 GT PP
That thing literally costs 5 times more than a normal fl820. If you’re really racing the car, there are bigger issues than the oil filter, like oil starvation from it sloshing around in the pan.
BlueCollarDaily
Shawn
2019 Mustang GT 400a
xo-5w50-q1gt ford is going to the SN Plus ( aka Dexos 2) it has detonation resistance in high compression or boost applications ILSAC.... the 1 in the part number denotes it last time I checked my local dealer had that in the 5w30 in stock.....
the MC 5w50 shears down to 40 with a few heat cycles anyway......
SSG 5.0
SSG 5.0
2017 Mustang GT
I can’t find pennzoil 5w40 on my local stores online smh. I’m trying to avoid deliveries because I don’t trust it.
Barrel
Hoonigan
Cars and Trucks
I mean, I also have a baffled Moroso oil pan. After putting $15k into the engine I'm not about to argue over a $17 oil filter. I'll find somewhere else to be cheap.
Roh92cp
Fort Kent Maine
Shawn
OW GTPP Whipple
I been reading this guys oil blog for years. He's and engineer by trade and provides an engineers approach to unbiased oil testing. He has tested almost every oil and provides new test on new products when they come out. It's a long read, but you can cut to the chase and read his oil test list starting here about 1/4 way down the blog. It's rated in PSI the higher the better. I use Amsoil signature series 5-30
The “WEAR PROTECTION RANKING LIST” itself, begins here:
https://540ratblog.wordpress.com/2013/06/20/motor-oil-wear-test-ranking/
engineermike
La
2018 GTPP A10
@Roh92cp , with all due respect I don’t put any weight in his “findings”. He has some things blatantly wrong in there, such as the mechanism by which zddp works, it only tests one small area of the stribek curve, and there is zero weight given to things like oxidation resistance and cleaning ability. He also doesn’t share his testing method. I must admit I was excited and convinced the first couple of times I referenced the blog but have since realized it’s not a good test.
moffetts
San Mateo CA
That’s great, OP is in a slightly different situation.
Barrel
Hoonigan
Cars and Trucks
The man asked for a better oil filter to use. I'm assuming he's not looking for the bargain basement filter you're alluding to. No need to get all snarky.
moffetts
San Mateo CA
Considering the stock filter is an FL500, a regular FL820 is already an upgrade at least in terms of capacity. The RS3 uses the FL500, so for street and light track use, even the FL820 likely isn’t necessary.
5ohcoyote
El Paso, TX
Nick
2016 mustang GT
I’ve used wix xp I believe.. now I’m using amsoil. Says it’s good for 25k interval change. Not going anywhere close to that but just what I’m using
engineermike
La
2018 GTPP A10
