Engine oil?
SSG 5.0
2017 Mustang GT
Only a procharger p1x installed, a couple of suspension parts and mainly a street car. I have been reading here in the forum lately that using 5-20 is a no go for a fi coyote? How true is that? I use Mobil1 full synthetic since the first oil changed.
SSG 5.0
SSG 5.0
2017 Mustang GT
engineermike
La
2018 GTPP A10
My favorite oil isn’t offered in 5w50 so I’ve been running 5w40 for the last 20,000 miles, all of which were supercharged. I don’t do uoa but I do measure consumption and it isn’t even measurable over the 10,000 mile interval. I’ve noticed no effects in the vvt. I can see commanded and measured cam timing in logs and they do as they’re told. I’m sure many folks have followed the instruction manual and run the 5w50 and I’ve not seen any complaints on this board.
SSG 5.0
SSG 5.0
2017 Mustang GT
What brand of oil are you using? I’ll read up on that 5-40 and 5-50 for sure.
engineermike
La
2018 GTPP A10
I’m using Pennzoil platinum euro 5w40. It’s an ACEA A3/B4 oil, which is a high performance spec.
robwlf
phila
rob
17 lightning blue pp LFP 670
i run pennzoil platinum 5w30 have been for over 2 yrs , if your going to track the car def run 5w/40 or 50, i see your in texas being there id run 5w40 or 50 summer month's prob get hot as hell so
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
Ford Motorcraft 5W-30 Semi synthetic blend. Great oil, cheap too. 5000 mile oil change intervals for me.
SSG 5.0
SSG 5.0
2017 Mustang GT
Thanks. What would be the next choice if the pennzoil isn’t available?
SSG 5.0
SSG 5.0
2017 Mustang GT
Probably stick with 5-30 because it’s mainly street and a weekend car. It does get stupid hot here lol.
United Arab Emirates
2018 Mustang GT 5.0
To be honest it's not only about how thick is the oil. It depends in the weather since the oil heat causes a chemical reaction in the engine oil, which causes the oil's viscosity to change
engineermike
La
2018 GTPP A10
Where are you shopping that Pennzoil isn’t available? I’ve ordered the euro 5w40 from amazon or Walmart, found it locally in stock at Advance. It’s not the easiest to find like regular Pennzoil platinum or motorcraft, but worth it IMO.
SSG 5.0
SSG 5.0
2017 Mustang GT
I’m staying full synthetic although I was told before, once I made a switch to full synthetic, I can’t go back to regular oil or semi synthetic. Never read up on it and kept it like that. I wonder how true was that.
khsonic03
Jacksonville, FL
2017 Mustang GT PP / 2016 F150 Lariat / 2018 Jeep Rubicon
NAPA also has the pennzoil euro 5w-40.
SSG 5.0
SSG 5.0
2017 Mustang GT
Local store in my area like autozone, advance, etc.. I’m going to start looking around when I get the chance.
