E85 Tune Thoughts/Options
cyberwired
South Central Texas
David
2019 Mustang GT Kona Blue 401A, A10, Performance Pack
Just trying to figure out the best course forward with tuning my car. I have a bone stock 2019 Mustang GT PP1 A10, and I live in a large Texas city with great E85 availability- 4 stations within 2 miles with E! So, my dilemma; I think it makes sense to get a straight E85 tune but from there I am conflicted.
I figure I can run E85 most of the time given Texas weather, but for those times I need to run 93, should I get a flex fuel tune as my other tune or a 93 tune? I am thinking it’s a good idea to minimize flashing tunes if at all possible, and from a convenience perspective,
I imagine I would be adding 93 to that/some quantity of E still in the tank. So if I flash the flex fuel tune on top of the straight E85 tune, will it trigger the alc % learning process by the tune being flashed, or will it only trigger by having a near/empty tank and adding fuel?
How much corn can a 93 tune tolerate being left in the tank or will I need to drain it nearly empty if I switch to a 93 tune?
Again, my ultimate goal is flexibility/convenience for the other than straight E85 tune.
Thanks in advance for all your opinions!
Zelek
Hutto, TX
2021 Mustang Mach 1
Yes, get a flex tune. Also get a 93 tune with emissions on. The Flex and E85R tunes I have don't have much of it on. Then you have a tune for every scenario.
Yes, the learn process starts when you flash flex tune on after your E85R tune. You want your car as close to E as possible before going to straight 93 or E85. That's why Flex is so great... No re-flashing.
E85R has a very strong mid range over flex but peak HP is about the same.
TheTxPilot
SoCal
2019 White GT Vert
What kind of performance bennifits could you expect with an E85 tune with 100% E85 in the tank VS. a flex tune with 100% E85 in the tank. Sorry if this is a dumb Q.
Zelek
Hutto, TX
2021 Mustang Mach 1
More aggressive mid range power as the timing hits a lot faster than flex. That's mainly the difference.
cyberwired
South Central Texas
David
Run straight e85 tuned where you are at. No reason to fiddle with flex or 93.
Absolutely! I plan to run corn near exclusively, but I know there are going to be times when I have to leave my home area that I want to be prepared for. Thanks for your feedback!
cyberwired
South Central Texas
David
Thats great advice, thanks! Luckily I live in Bexar County, no emissions testing at this point but its a good idea to have all the bases covered. Thanks for the help!
bootlegger
Enginerd
Mount Pleasant, SC
James
Ex 2008 Mustang GT Owner
This. Been running straight E85 for around 6-7 months. I toss in some Chevron Techron detergent every couple tanks, just to prevent deposits. Other than that, nothing special needed to run it every day.
Zelek
Hutto, TX
2021 Mustang Mach 1
I think the annoying part I can think of with E85 is having to fill up all the time. The car just drinks this stuff really fast even if you try to drive it not like a maniac. Everything else about it is great.
TnWHTMARE
Knoxville
2020 GT350 HE
Yah, I feel ya on that...i usually get around 160 miles on a tank. But, ya know what they say, gotta pay to play. :)
Zinc03svt
usa
stang
Timeless
South Carolina
2024 Grand Highlander Hybrid Max Limited
nate-roth
San Antonio, TX
Nate
2018 Mustang GT A10
Run the E85 tune, I live in San Antonio and that's what I do. No need for flex fuel tune really, just run the tank down pretty low and switch tunes while the car is at the pump. Car will run fine with a gallon of either, ive data logged a bunch and the car adjusts quickly. Flex tunes are neat but not really necessary and lack the aggressive part throttle timing tables, you will feel a pretty big difference stop light to stop light on the E85 vs. flex tunes.
cyberwired
South Central Texas
David
This is where I live as well. If you don't mind me asking, have you tested/logged Valero E85 and who's tune are you running? Valero are the 4 close stations that offer E. Thanks a lot!
