DW400 fuel pump running a JMS Boost a Pump?
Discussion in 'Forced Induction - 5.0L V8 Engine' started by robw_39, Aug 28, 2018.
  1. Tricky Dickey
    Tricky Dickey Active Member
    First Name:
    Vehicle(s):
    2016 GT
    Oct 7, 2018
    Henryetta, OK
    33
    Palm Beach Dyno won’t do it anymore either.
  2. Chainsaw
    Chainsaw Well-Known Member
    First Name:
    George
    Vehicle(s):
    2018 GT Magnetic Gray A10, 401A, PP1.
    Mar 13, 2018
    NH
    324
    122
    Occupation:
    Machinist
    0   0   0
    #33 Chainsaw, Oct 8, 2019
    Injector Dynamics should be releasing their brushless fuel pump soon. Said to pump over 700 lph. PBD has one now that they are testing.
    WickedRed and Tomlouns like this.
  3. HRSEPLA
    HRSEPLA Well-Known Member
    First Name:
    Sam
    Vehicle(s):
    2018 Mustang GT A10 3.0 Whipple, 2018 Jeep Trackhawk Hellcat, 2016 GT-R, 2018 F150, a few Turbo and Supercharged Foxbodies and WRX's
    May 8, 2018
    Wisconsin
    177
    239
    0   0   0
    I don't blame Jon, he's trying to keep our cars alive. My '18 Mustang was the last to be tuned by him in 2018 with the DW400/BAP/ E85 because of the many track tests and logs we did together. As I made changes and began dropping pulley sizes, my fuel pressure just wouldn't hold at the top of the RPM's. It just wasn't consistent or safe to keep supporting on a mass scale as a tuner in my opinion. I then made the switch to a full fuel system and all is well. (fyi- I was able to get down to the mid 9's @ 148mph on the DW400/E85/BAP but the pressure was dropping up top, for my experience on the HP threshold)
  4. Stymee
    Stymee Well-Known Member
    First Name:
    Joel
    Vehicle(s):
    2019 Mustang GT
    Mar 19, 2019
    Philadelphia, Pa.
    1,022
    298
    0   0   0
    Oh I get it, Lund was smart
    HRSEPLA likes this.
  5. sloride
    sloride Active Member
    Vehicle(s):
    2016 GT
    May 20, 2017
    ohio
    38
    How much boost were you running when you ran the 143mph before you switched over to the full fuel system?
  6. Phils15GT
    Phils15GT Well-Known Member
    Vehicle(s):
    May 13, 2015
    Albany, NY
    565
    76
    0   0   0
    I am on JMS BAP and ID1050x with my 19 GT, Hellion Kit on E85. Car traps 140 on 7lb springs.
  7. rANDIANDI
    rANDIANDI Cashfed5.0
    First Name:
    Andi
    Vehicle(s):
    Jul 18, 2017
    California
    39
    I can only share my findings from what i have experimented with.
    Lund Tuned: Jon Jr
    VMP GEN3
    L&M Intake Cams
    Twin 67
    Pmas Intake
    ARH Long Tubes
    FIC1000s + ID1300x2
    I had a GT350 Return Style fuel system with -8 feed and -6 return that maxed about on a 85mm (13psi) on E85 with losing fuel pressure after 6k rpm.
    I added a JMS BAP 18v and it held another 2 psi and on a 79mm (15psi) it started dropping fuel pressure above 5k rpm.
    At this point i swapped the stock fuel pump in the gt350 hat to Twin DW400s which held the 79mm with no issues alone.
    When i dropped down to a 69mm(18/19psi) and ID1300x2 the twin DW400s would not hold pressure and would drop below 60psi after 4k rpm.
    Jon jr said i can try the BAP with the DW400s and i did on my own time on and 18v it would pull to 7k before dropping fuel pressure. With it set to 22v it would hold through the full 7800 shift at above 75psi of fuel pressure.
    I was advised by Jon to go with a fore twin pump system as the BAP was a bandaid.
    So i think dual dw400s can support about 900rwhp and with a bap over 1000rwhp but i never dynoed the car so idk just my experience.
  8. VRP
    VRP Boost Loading...
    First Name:
    Chase
    Vehicle(s):
    2015 GT Premium
    Apr 24, 2016
    Senoia, GA.
    599
    175
    Garage Profiles:
    I ran 9.3 @ 149mph on a entire stock fuel system with BAP on race gas... Thats about the limits of the stock pump for sure, id imagine a drop in pump and BAP would support a lot of power on race gas alone not E85.
  9. Toy Cobra
    Toy Cobra Well-Known Member
    Vehicle(s):
    2018 GT
    Jan 28, 2018
    248
    133
    0   0   0
    That was a 4.88 pulley so around 12lbs give or take but the DA was great, around 200.
  10. sloride
    Vehicle(s):
    2016 GT
    May 20, 2017
    ohio
    38
    would you be able to share that log or say what the fuel pump duty cycle is. Thanks!
  11. Roush05
    Roush05 Well-Known Member
    Vehicle(s):
    2015 Mustang GT Premium
    Oct 13, 2015
    Savannah, GA
    298
    48
    Rating:
    100%
    1   0   0
    I'll try to when I get home. I want to say that it was at 48 percent but that might be a max value or something.
  12. sloride
    Vehicle(s):
    2016 GT
    May 20, 2017
    ohio
    38
    what lambda were you targeting or seeing when just on the BAP. Thanks!
  13. Phils15GT
    Vehicle(s):
    May 13, 2015
    Albany, NY
    565
    76
    0   0   0
    My lambda is .78 and doesn't move under WOT with my ID1050x JMS BAP and E85 with my hellion TT 19 on 7lbs. 140mph trap.
  14. sloride
    Vehicle(s):
    2016 GT
    May 20, 2017
    ohio
    38
    Thanks! You guys are lucky with those second set of DI injectors
Loading...
Share This Page
