Walbro Fuel Pump vs Boost A Pump
saiga488
Oklahoma
Just out of curiosity, why are so many people running a boost-a-pump or voltage booster with stock in tank fuel pumps vs running an aftermarket in tank pump like a Walbro/TI Automotive? Even most of the forced induction kits come with boost-a-pump vs an in tank pump replacement. The higher quality BAPs like the Kenne Bell or JMS are $300-$400 while you can pick up a Walbro for $150-$200. Installation difficulty is pretty simple with either choice so I was just wondering why so meany people running BAPs?
Reds197
KC
18 BASE (sold)16 LPF 62mm 16 Whipple 15 VMP MT-82
Boost- a-pump on Stock pump will flow a ton more than the 465 pump. Even without BAP a stock pump flows 90% of the 465 when using the stock basket. The output line size is the restriction when putting in a 465.
beefcake
Bethel
2018 Ford Mustang
either a bap for pump or a fuel system for e85 is what you want to do
phunk
United States
'15 GT-PP
You cannot simply install the Walbro pump to the stock fuel pump housing.
The stock pump has second output barb that provides fuel pressure to a pair of venturi jet pumps for in-tank fuel transfer. Aftermarket pumps do not feature this smaller secondary output. Could you custom machine a T fitting and screw around with hoses? Ya probably.
But the stock pump is no slouch anyway. It's a Delphi turbine pump and I will bet you that it's output is very similar to the Walbro 450/465/485 or whatever you like to call it.
SolarFlare
S. Fla
2015 CO GT
SolarFlare
S. Fla
2015 CO GT
Im not sure what the GT350 pumps are good for. Im talking about on a stage 2 procharger, to go E85. Cheapest route is Sai Li return system (~$950). Im wondering if simply running the GT500 dual pumps and 1000cc injectors on a returnless system. Or maybe the dual GT350 is they supply the same as the GT500 pumps.
dsp4848
Hutto, Texas
David
2015 GT PP Magnetic
Just curious, has anyone looked further into the GT350 pumps and what they are capable of? Is this truly a drop in pump for GT owners?
Davepurp
Wrentham, MA
2015 Mustang Gt Premium
Is there less of a failure rate with replacement pumps over a BAP?
whatsup62
Jupiter
Talk to your tuner.
I know Lund WILL NOT tune for E85 without a return style system.
Deadmau5
Procharger p1 stage 2
Little elm,tx
15gt
I'd love to know if the gt350 fuel pump would work for e85!!! If so I'd save soooo much money
