Deatschwerks X3 Fuel system
Nobuemon
Monrovia
Nikita
2020 Ford Mustang GT Premium
Is your installer going to utilize the SW pulse damper?
I was messing around trying to see how to go about installing mine in the Holly rails and here’s what I came up with.
It should be the same for the DW rails. I figure, why not try and use it.
Going to try to use it after finishing with the current setup troubleshooting, didn't wanna overwhelm the shop right off the bat haha
Nobuemon
Monrovia
Nikita
Here are the pictures! Hope your wisdom will help us find the correct path
NGOT8R
NGOT8R
Adrian
2019 Bullitt
Is the shop just having trouble mounting the rails or something else? I notice the mounting bolts aren’t securing the rails to the IM.
I also see that you guys were able to run the crossover line in front instead of the rear.
Check out this diagram here.
NGOT8R
NGOT8R
Adrian
2019 Bullitt
I meant to ask, what parts did your shop order that you were hoping to have overnighted? Just trying to get a full grasp on what’s been done so far.
Nobuemon
Monrovia
Nikita
Thank you for the diagram!
If it’s in the front and fully tightened, it’s touching/pressing on those lines/hoses you see on the left, and the shop thinks it is sketchy, borderline dangerous.
DW asked for my shipping info now, maybe they got some additional parts for me that I didn’t receive before.
Gonna keep you posted!
Nobuemon
Monrovia
Nikita
They didn’t order anything new yet, everything they have is what I gave them from my initial order from DW.
I meant before if the need arises to get something extra to make it work.
NGOT8R
NGOT8R
Adrian
2019 Bullitt
Let me think on this a bit and get back to you with a possible solution. Gotta make a quick run, so give me a couple hours and I’ll get back to you.
Okay. Another way to create more room in the rear for the crossover line is to delete your IMRCs and install a lockout kit. I have the MMR kit on mine. I had to do some slight modifications on it though. I’ll find the thread on how I did that and post it here shortly.
NGOT8R
NGOT8R
Adrian
2019 Bullitt
Nobuemon
Monrovia
Nikita
Nobuemon
Monrovia
Nikita
A quick update, DW is sending me 90-degree hose ends and 3 feet line itself to make it fit anywhere.
NGOT8R
NGOT8R
Adrian
2019 Bullitt
That should do it.
What’s that used for?
Thanks!
That’s where the Di pump‘s fuel line connects to. Look at the above diagram again. In the top right corner, the open female port on the left of the tee block is where the factory Di line plugs into.
NGOT8R
NGOT8R
Adrian
2019 Bullitt
Nobuemon
Monrovia
Nikita
Your DW X3 Kit didn’t come with fuel line and about 20-25 fittings to include various fittings? Should have been enough in that kit to account for about any plumbing situation.
This is the kit that I have.
https://deatschwerks.com/products/9-401-604-7032
Yup, I have the same one. Had enough fuel line for the designed plumping of the kit, barely anything extra. Not sure about the fittings tho, as far as I know there are a couple left but they’re straight, not the 90-degree ones. Maybe they include the additional ones randomly?
NGOT8R
NGOT8R
Adrian
2019 Bullitt
I ended up buying several extra fittings from Deatschwerks. I want to make sure I have more than enough. I may end up needing a little extra fuel line, but we’ll see.
