Dealer Replaced Engine Sounds different?
firestarter2
NYC
RR G350 Track
I have my motor replaced (2016) with a new R motor. I have noticed the new engine sounds different it also seems quieter.. I am wondering if I should be concerned.
My dealer is fairly incompetent so I am wondering what mistake they did would cause this.
DCShelby
DC
Robert
Be glad you got a new and better motor. If it sounds different but not bad, that's ok. My new motor felt much more balanced and smoother, almost flat 6 like from my 911. I'd go check all of the hoses and connections to be sure its all ok. For me, they forgot to move the coolant reservoir front clamp up to the nipple when the motor was replaced.
Shift
a Ford
My engine was smoother, and sounded different in a good way(meaner). Also seemed more eager to rev than my old engine.
jvandy50
H3249
AR
jason
23 Bronco, 18 ZL1-1LE
check the 2 connectors on the back of the intake too.
jvandy50
H3249
AR
jason
Back where?
i don't have any pics with me sorry, but there are 2(pretty sure) clip-in connectors on the very back of your intake.
i got my car back twice with a CEL after my motor swap and if i hadn't had a scanner we'd never found out those weren't connected. and i'm not the only one it's happened to.
DCShelby
DC
Robert
I had to have the rear cylinder block plate changed too, a few moths after the new engine. It had the metal trash bag sound at 4K rpm, till the new updated part was put in. Hopefully they did it for you when the new motor was put in. So keep an ear open.
firestarter2
firestarter2
NYC
RR G350 Track
I have no CEL but ill look thanks!
jvandy50
H3249
AR
jason
probably not it then. they left that unplugged then forgot to do the cam relearn procedure the other time. that one definitely change the sound lol. good luck!
firestarter2
firestarter2
NYC
RR G350 Track
Ill look anyway It almost sounds like one of the exhausts isnt open. I could be imagining it though. I noticed a whistling sound and the intake was loose.
jvandy50
H3249
AR
jason
those are known to get stuck, i'd check there too!
Kobi Addiction
Houston, TX
2017 Ford Mustang GT350
Back where?
He's probably referring to the IMRC connectors behind your intake manifold. You basically need to lay on your engine and stick your head back there to see and get ahold of them. Kind of a pain the ass for a few moments, but wouldn't hurt to make sure all is connected back there.
DCShelby
DC
Robert
Least you got the new rear cylinder block plate.
DIB2016
San Antonio
2020 H.E GT350; 1968 Ford Bronco Sport
Got the same issue. My exhaust sounds completely different along with a host of other issues.
