Cracked calipers?
key01
Chicagoland
2017 GT350 now gone to a great home.
Casting failure and glad you caught it. I had a bad casting on the tailpiece of a transmission in a new Corvette (sorry). Drove it home and fluid poured out onto my driveway. Towed it back to the dealer and they had to completely replace the trans with less than 100 miles on the car. Good times.
Niz55
Niz55
Us
17 GT350
Brembo told me I have to contact my dealer.
Anyways, I explained the situation to the service advisor and he said i probably damaged it when I was taking out the caliper . Lol
I already knew I was going to get a answer like this.
Parts guy hooked me up for $196 plus free overnight from Chicago.
Niz55
Niz55
Us
17 GT350
I also have to give them my original or else they will charge me $50 core.
galaxy
St Louis
'17 GT350
I F&$%ing hate that crap. You know what dude...$196 is an extremely small price to pay, and you know why?? If they had been putting brakes on your car, they would have never in a million years caught that crack. They'd put that thing back on and sent you on your way. I know they say pick your battles, but you should have shot back with that.
Niz55
Niz55
Us
17 GT350
I could of argued with them, but you and I know and everyone else that it wouldn't gone no where.
Plus I am in a situation i can't and won't put it back on.
Hubs are out
Rotors are out
Calipers are out
Brake lines disconnected
See not worth it....
Honestly I cant just walk in the dealer and hand them my caliper expecting a new one in return. But service advisor was just plain ignorant.
FP350S
Decatur, Texas
Robear
16 TY GT350
R U painting calipers yourself or having professionally done?
Niz55
Niz55
Us
17 GT350
Myself. I have done it many times with excellent results.
Vht high temp primer
Vht yellow caliper paint
Important step is to bake them for 1hr at 200F in order for it to cure . After that it becomes rock hard and no need for clear coat at all.
I did my 2015 gt same way and after 3 years it looks like day one .
tracktardicus
Denver CO
2020 Toyota 86
Any fault or damage in your braking system needs to be replaced, especially if you are tracking your car. The two worst things that can happen at the track: 1. Your car catches on fire. 2. Your brakes fail.
HoosierDaddy
Randy
It won't void it but they will not cover it. The caliper needs to be on the car in order for service department to warranty it.
You are probably right but I was very surprised when my dealer did a battery swap without the car. I removed the bad battery and took it to the dealer to be tested and hopefully replaced. The service writer said Ford requires the car to be towed in before they replaced the battery. I think its mostly to verify mileage. I talked to the service manager because I did not want the car towed because of risk of damage. He told the service writer to give me the battery if I promised to email a picture of my odometer with the mileage I had told him after I installed it. I worked the paperwork for the battery into the frame.
Niz55
Niz55
Us
17 GT350
Man the hand brake cable kicked my ass trying to take it apart.
Brian V
USA Retired
Native Earthling
2015ecoboost premium 201A Nav Sec Race Red
are you trying to tell me that you did all that wrenching on your GT 350 and did not invite me to bust me knuckles braking bolts loose ? Dang man I love busting my knuckles and to think on a GT 350 ...
What you don't like your suspension ?
Niz55
Niz55
Us
17 GT350
Changing out my current springs (Eibach) to steeda duel rate competition springs that they just released yesterday.
Epiphany
Global
I like to disassemble things.
It is indeed a PIA without a couple of dedicated tools that make the job much easier. Ford could have made a couple of minor tweaks that would have made things a lot easier/quicker. I struggle finding a legitimate reason why they didn't and instead chose to complicate the process.
galaxy
St Louis
'17 GT350
Honestly, I truly believe they in fact engineer stuff like this INTO the equation. I think they try to drive the DIYer away from working on their own stuff and driving that work back to the dealerships. Could be wrong, but that's my conspiracy theory.
Yup...that one sucked when I removed mine for paint. If I recall, I was able to get the spring far enough out of the way to get a socket on the bolt and just backed it out until the caliper came off. I don't think ever got the bolt out of the bracket or out from under that spring; I just left it there.
Brian V
USA Retired
Native Earthling
There is an adjustment point for the e brake which is located just aside the mufflers front attachment point . There you can adjust the cable to give slack enough to remove the cable attachments from the rear calipers .
