Codes P144A and P0193 (ugh..not again)
honeybadger
Just don't care
COTA
Kevin
Hi all,
Bit blown away - am feeling this is all related to the AC repair fiasco (where the engine harness was pinched), but want to do my due diligence and diagnose as best as possible. Eliminate all other options!
Context - on Saturday the car was giving me a random misfire code (P0300) while out at MSR-Cresson. We ran the codes at the local performance shop, Dog House Performance, and the car showed all parameters as good (fuel pressure, ignition coils, etc.) - just the misfire (and no particular cylinder). Misfires only happened at full throttle. Our best guess was bad plugs or bad gas because it only seemed to misfire when the car was advancing the timing. So, it was obviously detonation-related. I put new plugs and filled up with some VP100 fuel to clear things out. Car worked great for the 1 remaining session I made it into - about 45 mins of straight track time. No problems.
Then yesterday I ran it for about 3 hours of track time again with no problems. On my final 2 laps of my second to last session, it started acting like it had fuel starvation (power cuts, no check engine light). I come in, check things out - have fuel, no disconnected vacuum lines, etc. Go back out for final session and it freaked out as soon as I hit the track. CEL came on. Roll over to Dog House again and we read 2 codes:
p144A - Evaporative Emission System Purge Vapor Line Restricted/Blocked
P0193 - Fuel Rail Pressure Sensor Circuit High Input
Current hypothesis is that the vapor line restriction is causing the high pressure in the fuel rail since it can't evacuate. Thoughts?
Given that this car has had a few problems with electrical connections since the AC repair fiasco, I am wondering if it's related. The most common fix for P144A seems to be replacing the purge valve, but I would like to trace the circuit and make sure the connection from the PCM is intact. Can anyone provide a schematic for that?
Thanks for the help!
FLATPLANE
Buffalo NY
Billy
2016 Shelby GT350 Tech Pkg. 18 Chevy Silverado 1500 4x4 16 Lexus IS350 FSport
honeybadger
honeybadger
Just don't care
COTA
Kevin
Thanks, Billy. I appreciate it.
Now to dig in and see if it's electrical or mechanical. Can't figure out which one I dread more...
Austinj427
CO
2017 GT350
Where was the harness pinched?
Any chance the wiring for the purge valve runs through it?
honeybadger
honeybadger
Just don't care
COTA
Kevin
Update
I've tested the EVAP Purge Valve itself, the circuit and the PCV line heading back to the vapor canister. All passed. That leads me to believe this is in the vapor canister/vent control solenoid. Before I go tearing into things, I'd love to verify this circuit as well. @FLATPLANE - are you able to find this circuit as well? Not sure what it would be called, but it's in the emissions system and has the vapor canister and control solenoid.
Here's the parts list for the emissions assembly. Without testing the circuit, my best guess is the vent control solenoid - #3.
https://parts.autonationfordwhitebe.../emission-system-cat/emission-components-scat
As always, please chime in if you have any thoughts :)
honeybadger
honeybadger
Just don't care
COTA
Kevin
The wiring for the purge valve most definitely does. But it cleared my continuity test. Not sure if the second circuit I'm looking for does or not, though.
AgentOrange
Bedrock
Fred Flintstone, two leg power
Update
You can buy the Ford factory manual here for $130: https://www.factory-manuals.com/ford-mustang&28&160 Make sure to get the Deluxe Edition which has the hyperlinks. The non-Deluxe Edition does not have the hyperlinks and will drive you crazy. I use this website for all my cars. Works great.
Deluxe Edition: "DeLuxe Edition contain the same manual, but is full operational with hyperlinks (Interactive pdf), bookmarks detailed on three steps and also have the connector details."
tedj101
Wilmington, DE
Ted
2018 Shelby 350GT Steeda springs, sways, camber plates, toe links etc: 14 BMW 328d
Agreed. I bought the non-deluxe for my 2016 and wish I hadn't. Sometimes it doesn't pay to be cheap<g>!
<TED>
Lurker_350
TX
2016 GT350 - Tech
Is this the same as the Helms manual? About $50 cheaper at your link.
https://www.helminc.com/helm/Result...&Category=15&Keyword=&Module=&selected_media=
AgentOrange
Bedrock
Tank
9/11 - Never Forget
Above the Notches
G0853
In my opinion yes it is better than Helm bc it’s Ford’s service manual, which is what the Ford techs use to repair your car. Nothing wrong with Helm. Think of it as an OEM vs. aftermarket service manual.
@AgentOrange , could you check to see if the Ford Manual differentiates servicing between the aluminum and carbon fiber wheel service?
Thanks in advance!
Back to orginal programming....
AgentOrange
Bedrock
@AgentOrange , could you check to see if the Ford Manual differentiates between the aluminum and carbon fiber wheel service?
Thanks in advance!
I am out of town for Thanksgiving and do not have access to my computer that has the manual. They build the manual off of your VIN. However, it may contain instructions for both wheels. @tedj101 Will you please help @Tank with his question?
FLATPLANE
Buffalo NY
Billy
Tomster
Beware of idiots
Tom
Thanks in advance!
Jim, this is what the factory manual has yo say about carbon fiber wheels
honeybadger
honeybadger
Just don't care
COTA
Kevin
Thank you!
Manual purchased!
