Fenix
This guy is right. To my knowledge, as I started my career testing these dampers, they are still only made by one company. Delphi developed the tech with GM, however when Delphi went belly up, the dampers division was sold to a Chinese conglomerate, BWI. This was 2009-2010.For those who haven't owned a MagRide vehicle I suggest you really give that some thought if you plan on keeping the vehicle for a period of time it is not a cheap maintenance item and if more than one unit goes I assure you your wallet will be looking mighty empty once they are done with you.
The main issue was and is leaking rod seals. The iron particles suspended as part the MR fluid are in the micron size range and act as an abrasive over time against the chrome plating of the shock rod. This allows some particles to become embedded in the chrome and pass through the rod wipers, and up to the seals. Just google search magnaride problems and you will see it is not an isolated issue. At $800 or so each, they are not cheap to replace.
