Broken crankshaft
beetle6986
Harrisburg
16 Mustang GT, 04 Cobra, 2008 BMW 335
Do you have a link that points to this documentation? I specifically asked Roush today if I should be using 5W50 and they stated that I should not. They recommended I use what is on the oil cap from the factory
CJJon
Port Orchard
2020 Mustang GT/CS Convertible - Race Red
Whoever you talked to was full of shit:
NOTE: 5W50 SN PLUS OR SP FULL SYNTHETIC OIL IS REQUIRED to be used.
That is from the Roush install guide for a Phase 2 Supercharger.
Put whatever you want in there though.
Jackson1320
California
Jaxson
2015 mustang gt
Why would I run those as opposed to 5w-30? I’m sure there are many schools of thought on engine oil viscosity and why brand x is better than brand y. That being said I’m more than comfortable with my choice.
5w50 is what Ford recommends for supercharged coyotes
beetle6986
Harrisburg
He did tell me they recommend 5w50 for the 2018 and newer models when supercharged. He said for 2015 to 2017 to stick to 5w20.
Jackson1320
California
Jaxson
2015 mustang gt
First of all someone is absolutely talking out of their hemorrhoid factory. because the two shortblocks are basically the same as far as oil needs. Same tolerance, the same clearances, There were no changes to the main journals on both blocks, Same crankshaft, same rod, same bearings.
Second 5W 20 is too thin even for a stock coyote based on bearing clearances
olaosunt
Indiana
So how often do you need to change the oil when breaking in a new motor ?
I was under the impression break in oil for a few 100 miles then regular oil .
DrZed
Canada
Cam
2021 Mustang GT PP1 M6
Variable flow oil pump may have something to do with it on 2018+?
TGGT
TGGT
SoCal
2018 mustang gt
For me I did 5-20 semi synthetic initially. I drove the car from my work to home and back the next day and I changed the oil. Second oil change was also 5-20 semi. Drove it for 4 days to work and back and a couple of short trips on the freeway then I changed it. 3rd oil is mobil1 5-30 full syn with a bottle of Lucas. I will say that the shop I used to work at we would build corvettes and camaros. We would break them in on the dyno with a couple of low speed pulls that would progressively increase in load and rpm and then it was several full hits. For me it’s not about a certain amount of miles, but rather heat cycles. A good 10 -15 heat cycles and I’m good
Jackson1320
California
Jaxson
2015 mustang gt
I also change my oil a lot on a new engine. Also People don’t understand that they need to get on it and build some cylinder pressure to seat the rings
Jackson1320
California
Jaxson
2015 mustang gt
If you drive like a Girl Scouts and add a bunch of additives you will ruin the engine with 20 miles on it
TGGT
TGGT
SoCal
2018 mustang gt
Definitely this. I drove easy for a couple of miles and did 5-6 small pulls maybe 1/4-1/3 throttle. First to 3 grand then let it coast down in gear then 4 then 5. After that initial process I’ve been pretty easy on it, but probably in the next day or 2 I’ll go for a full hit. I used to run 5-50 and I think is necessary on cars that see a lot of track time. I’ll probably switch back to the driven 5-50 I used to run or rottela t6 5-40. My car is a street car first and maybe sees 1 good hit every couple of weeks. So for the time being I’m comfortable with the mobil1 5-30
Jackson1320
California
Jaxson
2015 mustang gt
You know exactly what to do. The motor should break in nice
Nola504boy
HOUSTON
Walt
Boosted 2018 Mustang gt
Im running the procharger crank support and the Kentic Crank saver stud… works way better than the ARP bolt
The guy who installed my crank support told me that my new kentic stud wouldn’t fit with my crank support so he used the supplied stud. Should I be worried? I mean I still have the crank support itself on the car. I just really wanted both of them on. I’m using the innovators west balancer as well. Not sure if that makes a difference.
