Borderline Spark Tuning - Humidity Effects
engineermike
La
2018 GTPP A10
As most have accepted, the challenge of making power with a supercharged Gen3 Coyote on pump gas is maximizing spark timing while avoiding knock. The rule of thumb is that 1 deg is 20 hp, but this gets worse the lower you go. I would qualitatively say that the goal should be to stay around 18 deg in most cases, and the losses really start stacking up under 16 deg.
When I was tuning the spark curves on my car, I was guided by an OEM engine calibrator to stay at least 2 deg below sensed knock when the humidity is high, and it should get minor knock at low humidity. I initially had my doubts because I had never heard of humidity being a significant factor before, but later noticed that I could run significantly higher timing without knock at 75 deg dew point than I could at lower humidity levels. I did some technical archive searching and found that it's a very well-established phenomenon that humidity has a significant effect on knock-limited spark advance. Spark humidity corrections are on the order of 4-5 deg during typical variations but can go as high as 10 deg(!) in extreme conditions. The biggest difference is on the humid end of the range at dew points of 70+.
To demonstrate, the two following logs were at nearly identical ambient temperatures, same tune, but one was at 68 deg dew point (humid) and the other was 45 deg dew point (dry). Commanded "borderline" timing was 16.7-16.8 plus 2 deg limited knock advance, for a total of about 18.7 deg at 6000 rpm. In the humid case, 3 cylinders knocked, resulting in 1-1.3 deg retard (.4 deg average retard). In the dry case, all 8 cylinders knocked, resulting in .2 - 2.5 deg of retard (1.5 deg average retard), some cylinders experiencing more than one knock event.
68 deg dewpoint:
45 deg dewpoint:
I do find it surprising that Ford accounts for timing adjustments based on load, speed, cam timing, lambda, coolant temp, and air temp, but not humidity. I did learn, however, that one OEM will soon be adding humidity sensors with spark timing corrections to their strategies. Now that I think about it, I'm starting to wonder if most of the reports of knock due to a bad tank of gas or winter gas are actually just the effects of atmospheric humidity changes, especially considering the absolute humidity is almost always lower in the winter. I have over 700 logs of my car and have never experienced unexpected knock that couldn't attributed to low humidity at the time.
Luckily, I have a close friend who builds circuits and programs microchips for fun. He designed and built a circuit that adds an external humidity sensor, intercepts the Manifold Charge Temp (MCT) signal, and modifies it such that timing is pulled or added as a function of humidity. The final MCT signal is a combination of both charge temp and humidity such that both can be used to adjust borderline timing. MCT was chosen because it has little other effect on the overall tuning other than just for timing adjustments. The following log data were taken within minutes of the above logs on their respective days, but with the humidity timing correction active:
68 deg dewpoint, humidity correction applied:
45 deg dewpoint, humidity correction applied:
You can see that the commanded spark timing (borderline plus knock advance) went from 18.7 deg without the humidity correction to 17.1 deg with correction for 68 deg dewpoint and 15.7 deg with correction for 45 deg dewpoint. You can also see that only one cylinder had incidental knock on each pull. At a 75 deg dewpoint, there wouldn't be any correction at all and the full 18.7 would be commanded even with the correction on. The end result is less power loss on hot, humid days because the timing will be more advanced, and safer spark timing on dry days.
I'm pretty excited about this because it will allow me to run the same tune year-around and take advantage of an extra couple of degrees of spark timing in the summer while maintaining the same knock safety margin.
I think the way most tuners handle it is they command a low borderline timing and let knock advance slowly feed in more timing. This will "sneak up" on knock, but then knock events will cause timing retard and the result is it will stay near optimal. I never liked this because you are guaranteed to have knock on every WOT pull, and you have to wait too long to reach a good timing number after going WOT.
SLIC V6
Randolph, NJ
Jerry
2019 Mustang GT Premium PP1 Act Ex. MT82 Stick
@engineermike,
Do you sell tunes and these Humidity Sensors/Adjusters?
If not, you should start!!!
I appreciate all of the Tech that you freely share on this site!
- Jerry
markmurfie
Hawaii
Mark
2015 Ford Mustang GT
1. You don't need to be doing this knock correction testing at 1.7-1.8 load with the potentially most intense knock.
2. Do you agree that compressor systems without air drying capability tend to produce compressed air that is saturated at ambient temperature? Meaning dew point of the flowing air becomes the ambient temperature or potentially higher on FI applications under boost. Kinda the same property that causes your air compressor tank to quickly collect water. Considering the pressue in the tank is usually maintaining 90-110PSI vs 14.7 atmosphere.
There is lots to consider and think about when it comes to humidity spark correction.
Grimreaper
Dallas
2017 GT
@markmurfie Wouldn't this be the main reason you were able to run timing usually reserved for e85 on pump with the whipple?They did some odd vct swings in an old dyno log you had posted too but the timing was pretty much 22 degrees flat from tipin to throttle lift.
Adds another thing to consider with remote tuners. Where are they located and average weather/ humidity when building their load/ timing curves that get repeated in most every tune sent out.
xr4x4ti
Minnesota
Tim
AWD 2017 Mustang GT 6MT Supercharged.
@engineermike, great info. Your posts are always very informative and well written.
I will be tuning my own car this summer. Do you do consulting?
Thanks!
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
@engineermike great presentation for the group. This concept you are addressing is well understood in the aviation world and by old school screw blown alcohol drag racers haha. It's great to see data as it applies to our mustang platform.
Where is your humidity (MCT) sensor located? Is this present in gen2 cars?
andrewtac
TX
mark
F250. 2020 GT 400A
First thanks for the contribution, i appreciate all you add here, saves me a ton of time and brain bytes.
Not only in the winter, but in TX in the fall and spring. We'll get a ton of rainy humid days, then a cold front comes and we all run out for the "boost" friendly weather. I was chasing an issue for a bit, maybe that contributed as I only went out to run in the nicer weather days.
markmurfie
Hawaii
Mark
I think what Im getting at is I got nothing from this post. Mike is doing some interesting research here we all know that, but the results being shared are not being collected in a safe manner. He knows this and is being way too conservative to really see the difference humidity correction makes.
Just my constructive criticism and not ignorant praise.
This "humidity correction" vs post "humidity correction" is tough too tell when 3 out 4 pictures are maxing out the 2* ecu controlled knock sensor feedback advance all shared results with in a 3* span. He is confident in it enough to allow it an extra degree and see 18* instead of 16.5-17 when the sensor says the air is humid. But when the sensor says its dry, its scaring him even more and he is pulling 1* making it an even more conservative approach than was already applied.
Personally I would calibrate it to only pull timing and never add, based off the question I asked.
My advice is stop doing WOT high load testing, and get familiar with knock at a much lower load. It doesnt have to be much higher then where the MBT and bordeline values actually cross. You can even demonstrate the effectiveness of your humidity correction by making that crossing point happen with out the knock sensor advance having to work as hard to find it.
If you want humid air going into your engine all the time, its as simple as using 100% water in a water/meth injection kit. The simpler way of accomplishing this correction imo.
engineermike
La
2018 GTPP A10
@SLIC V6 my buddy intends to sell the chip and sensor integrated into the MCT harness, but needs to build at least a couple more for testing first. We're kicking around an idea to add a feature to do a base offset of the MCT as well, so you could add or subtract from the base timing on the fly, with or without the humidity correction using a knob or even a simple user interface. I do a little side dabbling in tuning but I don't have a business.
@Grimreaper you're correct. If the tuner tunes it for 75 deg dew point, then he's running it into knock at lower humidities. If he tunes it for 25 deg dew point, then he's leaving 5 deg of timing on the table when it's more humid. I think most of them just allow it to knock then rely on knock retard.
@xr4x4ti yes I do on occasion as a side gig. I've managed to get some things working that the biggest tuners have shied away from, mostly because they don't like taking the time to do something they haven't done before. It can be quite time-consuming, depending on how unique the combo is. My favorite so far was a 9.5/1 Aluminator gen3 twin turbo that made over 1100 rwhp.
@markmurfie thanks for the feedback. I look forward to your version of the testing where you correct all of my errors, so we can compare notes. In fact, it would have been even better had you done all of this beforehand and shared it, as that would have saved me the time and prevented me from doing it wrong. I'm aware of water/meth injection and I've used it in the past. I prefer not to go that route again and opted for a more seamless driver/owner experience this time.
@engineermike
Wild info and data analytics compilation along with excellent tech!! This is very cool info that you're sharing (and the testing)!
Brilliant!
If this comes to be a part available to the M6G/S550 community, will the end user need a read/write device such as Forscan to install the sensor - or will this be a "plug-n-play" item with minimal Forscan/coding/Can Bus knowledge needed?
engineermike
La
2018 GTPP A10
Brilliant!
Thanks! I really appreciate it, but I have to give more than half of the credit to my Electrical Engineer friend who designed it electronically and built it.
The device has a programming/monitoring cable and can plug into a laptop. There is an app that can monitor input, output, pause the correction, and re-flash the curves on-the-fly with uninterrupted output to the PCM. I've actually been testing these features today. It's really cool to watch the borderline spark timing step change up and down when you re-flash the device.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Can you change things with the engine running?
engineermike
La
2018 GTPP A10
Yes for sure. The attached shows the shift in mct and borderline timing using two different maps and then pausing the correction completely all while driving.
