spark plugs
Boduke0220
NC
2015 GT PP
My Brisks went bad at 4K boosted miles, switched to NGK and been good for almost 10k now
dubster99
Nor*Cal
2015 Ingot Silver GT PP
I pulled my brisk after about 8k and they looked flawless, but switched to NGK anyways just to try em out.
beefcake
Bethel
2018 Ford Mustang
we have the ngk and the brisk available
robwlf
phila
rob
17 lightning blue pp LFP 670
so 6510 is the go to for s/c just want to make sure before i get the wrong ones im roush phase one i havnt pulled the plugs yet im just getting stuff together for spring time
Obsol3te
Hope Mills, NC
'15 GT PP
NGK 6510's and im at 24k+ miles on them.
Going to be changing them this spring regardless. Car still runs great
robwlf
phila
rob
3beeps
www.instagram.com
'17 GT
I'm running NGK 6510 as well. Had a misfire with the plugs gapped to 0.028 on 12+ psi so we tightened the gap down to 0.024 now.
Only good things to say so far about NGK, though. I replaced the plugs too just in case but they looked perfect.
z06psi
Evans, GA.
Andrew
The pot stirrer
So I had the Brisks and two failed on me within 15K miles. Switched to 6510s and I have a slight misfire. Need to gap them down further I think. I am at 14lbs with a .032 gap.
BrazukaV8
Los Angeles CA
Carlo
Mustang gt PP
My brisk didn’t last 5k miles. My motor started shaking one day. I was like damn boosted life didn’t last long. Pulled the plugs replaced with ngk and 16k Miles so far no issues. Brisk plugs are garbage.
Coyote Red
Port Lavaca,Tx.
Alan
2016 5.0 Coyote Red
I've used NGK in one of my projects, now I am at 23,750 miles and want to change my oem to NGK but Coyote Red isn't boosted. Will the Iridium work for my pony in a hotter plug?
robwlf
phila
rob
they will just dont get the 6510s cause there one step colder im not sure of the number on oem heat range on ngk
im on the roush tune so i think thats only 9 psi or 10.. from what ive read i should gap at .032
Barrel
Hoonigan
Cars and Trucks
Keep the gap a little tighter - .028 - .030.
