Bartly
Mind a question? So going with your gap/psi ratios, wondering what the downside is to gapping say a ProCharger car to the recommended .035" or even .032" when the boost is only 8-10 psi? Going by your examples it would seem like 8-10psi should be more around .037-.038". Just curious what the thoughts are on that?Seen in many times over the years tuning turbo cars. Your issue does sound like spark blowout to me. It can get better as the car gets hot but it is still doing it most likely. Check gap and close by 0.002" until it clears up. We would gap at 0.035" at 15psi, 0.032" at 20psi, 0.030" at 25psi, 0.028" at 28psi and 0.026" at 30psi.
Wrong heat range plugs or weak/bad plugs can cause as well.
