Bilstein installation
moderatespender
alabama
2018 mustang gt
I have steeda adjustable bump stops on my base stock shocks will they work? I see people using BMW ones. Anything else I need. Not upgrading the rear shock mounts. Taking to shop to install.
Thanks
shogun32
Northern VA
anything will work. just shorten them up (arrange stack) to be less than 35mm with a min of about 20mm.
Gojr47
Winter Haven, Fl
2015 GT
The rears won't work. You don't need them for the front.
moderatespender
alabama
2018 mustang gt
What is the part # for the BMW ones? Anyone else think the steeda adjustables will not work on the rear shocks?
shogun32
Northern VA
The steeda "don't work" because the inner bore is too small I believe. Take an Xacto knife and slit the ID and you can shove them on.
moderatespender
alabama
2018 mustang gt
Ok thanks what is the part# for the bmw ones that work. I read people talk about it but no part #
Chef jpd
Brooklyn, NY
Roadway 5.0
Strassejager
New York - USA
2016GT PP 6MT
Emilbadal
Socal
Emil
2016 V6 Auto DIB
Just curious, what torque specs did you guys used for the front strut center nut on your Bilsteins?
Emilbadal
Socal
Emil
2016 V6 Auto DIB
Thank you! The reason I asked was that in the Bilstein's installation manual, it calls for 54 ft lb for the M14 thread size which is a bit lower than the 76 ft lb that Ford call for.
S550HPP
PDC
2022 HPP Vert
I would follow Bilstein spec that's 30% lower than the Ford spec which is super weird.
