barron64
- Jul 25, 2018
- Auburn, AL
- 2018 Mustang GT convertible PP1, 6sp, 2006 Toyota Tundra Dbl Cab 4x4, 2009 Acura MDX, 2007 Toyota FJ Cruiser
I first noticed the "BBQ tick" or "typewriter" tick at around 2000 miles on my 2018 GT. I currently have 3200 miles and have not changed the oil as of yet so still running the factory fill. Couple of thoughts on this...I sold a heavily modded 1990 turbo Miata, I had built and loved over many years, to purchase the Mustang and a common issue with these early Miata's was lifter "tick". This "tick" was actually caused by HLA's (hydraulic lash adjusters) bleeding down and being very finicky with oil in general. Especially after an oil change using Mobile 1, 10w-40wt. I had looked into changing out all 16 HLA's but found a much cheaper fix. A friend of mine who had a lot of experience with Miata's said to try some Rislone oil treatment in the yellow bottle. This stuff worked a miracle on the HLA's...I just added 1/2qt at every oil change and the lifter tick totally disappeared. The "tick I hear in my GT sounds a lot like a lifter tick or a loose timing chain tick, which by the way probably uses oil pressure to keep the proper tension on the chain. Also, I have noticed that I don't hear the tick unless the car has been totally warmed up and then shut off to sit for say an 30 mins to an hour, allowing the oil to fully heat soak. Once restarted you hear it but it gradually fades away. Has anyone tried using 5w-30wt instead of the 5w-20wt? Just wandering if the 5w-20 is just a litle too thin, especially when heat soaked, to keep the valve train, and or timing chain tensioner's, quiet under a hot restart. I will be adding a bottle of the Rislone oil treatment with my 1st oil change but would like to hear any thoughts on running the 5w-30wt full time first.
