accel
I cannot help but keep thinking about connection between oil change and bbq tick. I know there are users who had tick even before the change (me included), but still there's plenty of those who get it right after the oil change.
A lot of talks regarding different kinds of oil but with no outcome.
So what if coyote is very sensitive to temporary oil starvation that happens every oil change.
Some coyote engines are more under danger than others depending on actual tolerances, but every oil change is a challenge.
If you drain oil properly, how much time does it require the pump to refill the system completely upon first engine startup right after the change? That's with tick happening in the end of oil passage - cyl 3 and 4 at passenger side.
I was reading liqui moly mos2 oil additive description and found this :
"MoS2 was originally developed to maintain lubrication in piston-driven aircraft engines in the event of a loss in oil pressure and to prevent complete engine seizure."
So I wonder if adding that oil additive shortly before oil change might minimize or eliminate the risk of damage?
