TheLion
By the way, getting back to the purpose of this thread once again:
This is one of the primary reasons why the 5.0 is sensitive to oil viscosity and how that viscosity changes over the temp range. It uses floating roller rocker arms. If the lash adjuster (the cylinder with the cone shapped top on the opposite side of the rocker arm) isn't pushing the rocker arm against the cam lobe fully or with enough pressure (thus the rocker arm's fulcrum height changes as the lash adjuster is the fulcrum point), the cam lobe will smack against the roller and make a tick. The more lash there is (aka the less the pressure the lash adjuster is applying), the louder the tick will be. It may also vary as oil pressure varies with RPM. It's much more likley to tick at low RPM than higher RPM as oil pressure is less, but the valve spring pressure is the same and also as the oil thins (either from acids aka use or from temp or both).
My 5.0's been ticking off and on with PUP, never did it with MC semi-syn. It was really loud just a few days ago in a parking lot, almost sounded like something was wrong at first which caught my attention. But once it cooled off it was completely gone. As the oil thins, it seems to get noisier or with lots of stop and go when oil temps rise. I also noticed that PUP 5W-20 is much thinner at room temp going in (during oil change) vs. MC 5W-20 and immediately noticed the whole valvtrain was clankier despite it meeting Ford's own spec and being a factory speck viscosity. I will switch back to MC 5W-20 at the next oil change unless I can find something with a more suitable properties, but MC is probably more than good enough, so I may just stick with that.
This might explain (pending there isn't a major problem like a spun rod bearing) why some people get ticks some times and not others. It also explains why quite a few report ticking after the first oil change when many people switch to something other than MC 5W-20. Again this is assuming you don't have a defective lash adjuster or a rod bearing issue. The cam phasors (which there are 4 of) can also be affected by oil viscosity, too little and it may not have enough pressure to hold it's position (it's CTA or Cam Torque Actuated, so it moves position by using the valve spring energy, the oil is then pumped into to hold it's position once that is reached as oil is in-compressible).
