ABS delete?
Nctong01
Nctong01
Kentucky
'17 Big Turbo Mustang Build, '17 Turbo Silverado, '16 AMG GTS, '99 Turbo Integra
These are the best modifications LOL, but I am curious myself as I am always looking for ways to ditch weight.
I contacted Aerospace; I'll update the thread when I get a response back!
Nctong01
Nctong01
Kentucky
Don't think you can delete the ABS module with it. That said, I'll be doing my own delete...doesn't seem to difficult. I'll post it up if people would like when I'm finished.
luc
CA
2017 GT with PP
Or if anyone has close
Thanks buddy. Secondary is the feeling of a mechanical pedal...I do find it appealing to feel more travel and the actual tension rather than having a shorter stroke on the pedal.
That has nothing to do with the abs and everything with the ratio between the calipers pistons sizes/fluid volume and the master cylinder bore size
If you want more travel and softer feel, use a smaller bore m/c
The system is 100% “mechanical” until the abs pump and solenoids kick in
Nctong01
Nctong01
Kentucky
Correct, which is why I'll be using Aerospace's setup--that's what I was referring to.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
It should disable everything. I also fail to see why anybody would want it off, the only thing you get from it is the ability to lock your wheels and crash.
I would just pull a wheel speed sensor and that will make it go into an ABS fault.
that connector doesn't disable ABS when I tested it myself. (2016 GT PP)
perfweld
Northern CA
2015 Ecoboost Mustang
Anyone ever find or make an ABS delete ? Im in need of one, I converted my car to Manual Brakes a while back and something is just not right, im hoping if I get rid of the ABS they might work better. Thanks
chesbro22
ohio
Brandon
2017 gt350
Is there any update on this? I just installed my manual pedal from aerospace and really want to get rid of module for weight saving.
Flyhalf
CA
www.youtube.com
Alessandro
Mustang GT 18 10speed auto PP1 , GT500 '21
Abs is way faster on roadcourse.
When u unplug everything (plug behind the airfilter) the Abs stays on (just with slighty different bias.
Abs is at least 2 or 3 sec faster on roadcouree vs no Abs ( in a 1. 30 lap)
chesbro22
ohio
Brandon
2017 gt350
My car is a drag car so only doing it for weight.
speedracer99
Georgia
2018 GT
I am in the process of this now for my road race car. Moving to a diff class and abs is not allowed. im removing the pedal assembly and all the abs stuff (I'll be using a wildwood or tilton pedal setup with balance bar). You will have to go to a ford performance control pack for the car to run as the stock wiring and boxes won't work if it doesn't see the abs parts. I have done extensive research on this and even had some ford engineers helping solve this - since its all can bus linked it's impossible to remove the abs and have the car function.
Flyhalf
CA
www.youtube.com
Alessandro
Not sure I commented already. Unless
Requested by a specific class.
NO ABS WILL ALWAYS BE SLOWER. especially with a heavy car like ours.
We have multiple example of really Fast drivers being slower only because the car has no ABS.
Alessandro
luc
CA
2017 GT with PP
Curious, which racing organization and class requires that ?
VictorH
South Carolina
Victor
2021 Mach 1
Any car running 24 hr LeMans. I didn't know that a year ago, but evidently ABS not permitted for any classes at LeMans. They can adjust brake bias F:R but that's it.
