ABS delete?
Nctong01
Kentucky
'17 Big Turbo Mustang Build, '17 Turbo Silverado, '16 AMG GTS, '99 Turbo Integra
Thought this might be the best forum to ask as I know some guys run/prefer manual brakes for track.
Has anyone done one for an S550? I’m finding ABS delete plates for every chassis but ours.
ksampler
CO
Preston
2016 Comp Orange Prem. W/ PP
Pull abs fuse?
It's not even that hard, under the hood on the right side there is a connector that doesn't appear to go anywhere, just unplug that and it disables ABS, Stabilitrac, and Traction Control.
strengthrehab
Houston
Ken
2016 DIB Base GT with PP
I've pulled it and still have ABS.
Nctong01
Nctong01
Kentucky
Not trying to just disable, trying to remove the system completely.
ksampler
CO
Preston
It should disable everything. I also fail to see why anybody would want it off, the only thing you get from it is the ability to lock your wheels and crash.
I would just pull a wheel speed sensor and that will make it go into an ABS fault.
ksampler
CO
Preston
Nctong01
Nctong01
Kentucky
kz
West Chester, OH
Mustangs & F150
It does not disable ABS. I also fail to see why someone would not want it. Better ABS (like Bosch Motorsport) or better calibration - yes, none - no idea why.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
OP is building a drag car.
Nctong01
Nctong01
Kentucky
Or if anyone has close
The removal of the weight is the concern over defeating the functionality.
Thanks buddy. Secondary is the feeling of a mechanical pedal...I do find it appealing to feel more travel and the actual tension rather than having a shorter stroke on the pedal.
