X-Pipe Install Question
Ewheels
SoCal
Eric
I know the install is straight forward but what is the best/easiest way to cut the pipe?
Is the answer sawzall or is there a pipe cutter that will work? Currently, I have a Dremel or an angle grinder at home but I don't think either of those are the best solution. So if I have to buy a new tool, I'd rather get the cheaper one.......though I suppose I could borrow a sawzall.....
EDIT: didn't realize sawzalls are pretty cheap. I'll just go that route.
MAGS1
Somewhere in Middle America
2022 Mustang GT
Sawzall works just fine. Just make sure you file where you cut the pipe so there’s no burrs that interfere with fitment of the X pipe.
WD Pro
United Kingdom
Lime GT
If time isn’t a big factor, a hacksaw and grinder give perfect results :like:
Remember to check your pipes for irregularities or rough weld seams that could affect clamp effectiveness and / or sealing :
Use good clamps - comparison photos :
Do you have active exhaust ? If so, I have some more tips … :wink:
WD :like:
Ewheels
Ewheels
SoCal
Eric
WD :like:
No active exhaust here. I'm just doing this for quick weight savings
Vert
Indiana
Whipped 19 GT Premium
Just buy an exhaust pipe cutter, they are cheap and make a square cut.
