Windows not working
neillv6
uk
Neil
mustang gt 5.0 v8
Hi
my 2016 mustang rhd has had an intermittent fault with the drivers window in that it sometimes wouldn’t go up or down.
today for some reason it’s completely stopped working, but also the passenger window. I thought maybe the drivers switch was faulty, but I’ve tried to operate the passenger window from the passenger door and that also isnt working.
I thought maybe a fuse, but from what I’ve read, it has separate fuses for each window, so can’t see both fuses blowing, and with the intermittent fault, again can’t see it being a fuse.
Any suggestions where to check? I need to get the drivers window shut as it’s currently in the fully open position.
Thanks
Swtbabybilly
Mamaroneck ny
Will
19 gt
Some cars if the master window switch is bad it won't let any windows operate like some old Hondas even in a 4 door car if the master switch doesn't work none of the windows will work. Not sure if mustangs are like this maybe someone can share a wiring diagram and you could jump the switch and see if the other window works, best of luck
neillv6
uk
Neil
mustang gt 5.0 v8
Anybody else experienced this? Don’t want to throw parts at it. I’ve checked all fuses and all good
Skye
≈39N
"Skye" Mach1 N2144
2016 and living in the UK. There are two general areas I can think of checking:
- While you've already reviewed the cabin fuse panel, feel the carpeting in and around that area, for water. See if any moisture is in the cabin
- Consider removing at least one, if not both door panels to perform a general inspection, for water leaks, loose connections, etc.
The S550s have several key areas where water can be allowed inside the cabin, doors and trunk. Enclosed are a series of links to water leak threads. Not all of these will apply in your case.
Good Luck. :please:
Master Thread of Water Leaks
https://www.mustang6g.com/forums/threads/water-leaks-master-thread.123828/
A-Pillar
https://www.mustang6g.com/forums/th...-s550s-a-pillar-water-intrusion-leaks.178242/
https://www.mustang6g.com/forums/threads/condensation-inside-front-and-rear-windows.209085/
A/C Evap Core
https://www.mustang6g.com/forums/threads/ac-evap-drain-tube.126141/
Battery Box
https://www.mustang6g.com/forums/th...battery-box-if-your-car-stays-outside.201220/
Cowl
https://www.mustang6g.com/forums/threads/cowl-drain-valve.132078/
Quarter Panel and Trunk
https://www.mustang6g.com/forums/th...ater-leaking-into-rear-quarter-panels.143545/
https://www.mustang6g.com/forums/th...ear-quarter-panels.143545/page-2#post-2940946
https://www.mustang6g.com/forums/threads/trunk-water-leak-did-i-repair-or-cause-issue.148040/
https://www.mustang6g.com/forums/threads/trunk-leaking.15806/#post-2695720
https://www.mustang6g.com/forums/threads/water-in-trunk.88100/#post-1959273
General Search of 6G Leak Threads
https://www.google.com/search?q=mus...HS6iLI8QrQIoAnoECB8QAw&biw=1462&bih=739&dpr=2
