- Sep 29, 2016
- Northern Virginia
- 2019 PP1 GT Kona
- Banned
- #16
You've done 2 dyno runs, on 2 separate occasions. Detail out the exact situation with the gas in the tank for those 2 occasions. Did you put the gas in the tank yourself both times? Did you get gas from the same place both times?94 is the highest grade here and my car is tuned for it. The gas came from my local gas station , I ran the dyno on a half tank of gas
Look, I'm 90% certain it's a gas thing. It's possible someone at your shop dropped some octane boost in the tank for the 1st dyno run, or you got some bad gas for the 2nd dyno run. Maybe you didn't pay attention, and you put the wrong octane gas in before the 2nd dyno run. With the temps cooler for the 2nd dyno run, the power should have been higher.
Any other differences you can think of? Any other mods you've done between the 2 runs?
I'd also consider what the real benefits are from a CAI, LTHers, and a tune. The CAI probably does nothing, if not actually a negative, the LTHers might help a bit, and the tune is the main change.
