HKusp
- Jul 22, 2021
- Hampton, Md.
- Jason
- 2018 Mustang GT
If you talk with Mike, you'll see that in his opinion, running no cats isn't very good. He feels like it throws some of the data off that the PCM uses to run the car efficiently. It can be compensated for to a degree, but he feels like it certainly isn't ideal. He runs cats on both of his personal vehicles, albeit, I know at least one is using GT500 cats. Not sure on the other.Which brings up the NEXT topic/question. If the defoulers artificially reduce the 02 measured signal, then how do they keep the wide bands "calibrated?" I'd imagine that if you were going to use the narrow band sensor as a home base, then it would have to incorporate a reduction value (i.e. if it's expecting a catalytic converter to reduce the O2 content, then the only way it can sense any drift in the front O2's is based upon an anticipated reduced value to the rear.) So if you're tricking or fooling them, then that adjustment factor is probably not spot on or exactly the same. What do the tuners do (previously) if the rear O2's are some sorta calibration check?
