Whipple E30 or no?
thewicked5oh
nebraska USA
selvin
Hey am I able to pump E30 without a tune for it I’m currently on a 93 Rob shoemaker tune asked him he said we could get away with it but never responded again his customer service highkey a**
2019 Mustang GT 10r80
-3.0 whipple
3.625 pulley
95lb DW injectors
DW400 Fuel pump
robvas
MI
2011 GT
I do it on mine.
Add a gallon of E85 and check your AFRs and short term trims. If they look okay add another.
Will it add timing? That's another thing to check
engineermike
La
2018 GTPP A10
2% ethanol means 1% fuel trim, roughly. So if you go from e10 to e30 then the trims will run 10% higher than normal. Does that make them too high? Depends on where you started. If trims were near zero or negative then it’s probably ok.
But like @robvas implied, you might not gain power, depending on how the timing calibration is set up.
thewicked5oh
nebraska USA
selvin
Might be able to drop a pulley size
So how would I go about checking my fuel trims and where I started by doing a datalog through the TDN app or how ? would I have to plug into a laptop and datalog through there on HPT?
J17GT
IL
2017 Mustang GT PP
You would need to use VCM Scanner on a laptop to capture a log.
Pistol_91
Clearwater
2020 mustang GT
Sounds like a lot of work for potentially no power gain doesn't it? LOL
ZXMustang
US
2025 Mustang GT
Yes you can. Straight up answer without guessing but having seen, tuned and tested this scenario.
Jasonb543
Detroit
Jason
1993 fox
He told you yes basically, get the app, go easy for a tank or 2
Make sure she feels good!
I love running E30! Solves basically all of the 1000HP cars fuel/burn needs
Tuners and fuel system companies hate this 1 simple trick! 😅
thewicked5oh
nebraska USA
selvin
I definitely will test this out can’t lie
