Which oil filter for the 2018?
matthewr87
2018 GT350
Is the 2018 compatible with the updated oil filter that started being produced for the 2019+ cars?
Or should I stick with the older filter that is listed in the 2018 manual?
sox3
Newark, Delaware
George
2019 GT 350 Performance Blue
I would go with the 19 filter, imo
proeagles
Covington, LA
Scott
2019 Shelby GT 350, 2019 BMW X3, 2019 Honda Civic
Curious what the dealer is putting in now. When they update something that is compatible, they usually use the new.
Sur3n
Suren
GT350
I just got my 17 changed by the dealer yesterday, they put on FL-2062. Possible they just went off the manual or not sure about the new model. I only had them do it so they can track the oil consumption.
matthewr87
matthewr87
2018 GT350
So no consensus I guess? I just want to make sure that if I use the newer filter design I won't run into issues regarding oil pressure, etc.
matthewr87
matthewr87
2018 GT350
galaxy
St Louis
'17 GT350
I’ve posted a thread about it and even asked in a couple other threads, but crickets, thus I guess I’m the only one that’s done it...but I swapped to the 2087 and my oil pressure I higher across the board; all temps, all driving conditions. Has not caused any issues but it’s always weird when you see a change like that. There is zero reason mechanically to not run this filter or for it to not be backwards compatible.
lightrules
West Coast
Yes
interesting data point. i'd hope FP would be able to tell us definitively. i will need to find out which to use pretty soon as my oil change is coming up.
Rubyred17
Kentucky
2017 GT350
Ok I know I am going to be an outcast for posting this but I sincerely hope that my Gen 1 (in my 2017) with the old canister filter holds together because I really like that filter. Yes, they perhaps tend to loosen over time but it takes 10 minutes to climb under the car with a torque wrench to check it. The 5.2 was engineered with that filter so it must mean something.
matthewr87
matthewr87
2018 GT350
Could the rise in oil pressure after your oil change be attributed to fresh oil with higher viscosity than your old oil (which had a lower viscosity due to shearing over time)?
galaxy
St Louis
'17 GT350
No. That’s been asked, but no. I know what my oil pressure looks like after a fresh oil change. This ain’t it.
s2ms
Seattle
1966 GT350, 2017 GT350(sold), 2013 Boss 302
I also installed a 2087 on my last oil change and noticed the same thing
