Which drop springs with blower setup?
Burkey
2016 Mustang GT
What are you trying to achieve? The fact that you referenced “drop” seems to indicate that you’re concerned about the impact of the added weight on ride height specifically. Is that correct?
crcpdx
Charlie
I had the sp083 springs on my last car and loved them but it was N/A. I wasn't sure if it was too stiff a spring for the front since I am looking for strait line traction a bit more now that I am boosted. All the the "drag" spring combos have much softer front springs so I just assumed.
Yes, it really depends what you are after. Comfortable daily driver, progressive spring, straight line acceleration, drag spring. I wanted a good all around car, so for me the compromise was the SP083.
tj@steeda
Timothy
For our S.C. equipped Steve McQueen Edition Mustangs, we utilized the Steeda Dual Rate Springs - which we have been very happy with.
Also, If you plan on keeping the stock shocks and struts, you can go with our Steeda Sport Progressive Springs or our Minimum Drop springs.
The Sport Progressives will have a great ride and lowers front 1.125" and rear 1. When you add a supercharger, the front will drop about another ¼ inch. Minimum Drop springs ride very good too and will lower the car about ½ an inch all the way around. And like the Progressive springs, adding a supercharger will drop the front about another ¼ inch. Be sure and install our Steeda Camber Plates when you order the springs.
Let me know if I can put you in contact with one of our build experts to assist with your build!
TJ
West TX GT
Ian
2018 Royal Crimson GT
How much of a drop would the dual rate springs be?
tj@steeda
Timothy
Vegas5OH
Las Vegas
2016 5.0 PP
bmr fi drag springs are fire
Red5.0
Houston,TX
15 mustang gt race red non pp
Personally I am most concerned with ride comfort being priority, then would be aesthetics along with better handling. The car will be mainly see regular street driving as I don’t plan to track the car.
Red5.0
Houston,TX
The main thing I was worried about it’s the additional weight with a blower lowering the car even more than advertised on any drop springs. From what I have seen the additional weight lowers the car about 1/4” more than advertised on any spring so I will take that into consideration on the lowering amount.
m3incorp
Georgia/Colorado
James
That's about what I noticed on mine. Interestingly not all vehicles have the exact same ride height, stock, even with same suspension... Maybe the Premium adds just enough weight to make a difference.
Gregory347
LI, NY
Greg
2019 GT A10 PP1, 1987 Buick Grand National, 1985 Mustang
Steeda drag springs using factory PP1 struts and shocks with Procharger weight up front. Was somewhat concerned it may be a bit low in front but its not the case. The stance/rake in my opinion looks just right and the ride and handling are perfect for my needs. Front doesn't scrape driveway aprons or parking lot speed bumps at all.
West TX GT
Ian
What about mixing rear drags with stiffer than drag fronts?
