What octane do you aim for when using octane booster?
Milktasd
Mississippi
1996 cobra, 2000 Sonoma LSx, 2021 velocity blue gt
For boosted people that are adding octane booster when they fill up, what octane are you aiming to get? 94? 98? 100? Etc
Back in the planing stage of my future build and I was thinking of getting a whipple with a 93 octane tune and add a little Boostane to each tank just to be sure I’m getting good octane level. Aim for 94-95.
engineermike
La
2018 GTPP A10
Depends on your goals. Technically you could make basically e85 power if you add enough and tune for it. Otherwise it depends on your goals and how the tune is set up.
robvas
MI
2011 GT
I personally just add a few ounces for a little protection. Not relying on the tune being that borderline.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
engineermike
La
2018 GTPP A10
100 octane gas vs 100 octane E85 ... Kinda. E85 has one big advantage ... cooling.
Oh I get it. That’s why I said nearly. Same boost and timing, e85 is worth a couple % more hp. I do think you could hit 21 deg timing on boost and pump gas with enough octane booster.
SnowFox
Mn
Grabber
2022 GT, 2017 ECOboost, Saleen S351
Just a few ounces for some protection and piece of mind
engineermike
La
2018 GTPP A10
The problem is that, depending on how the tune is set up, adding octane booster may not make it safer and could even make it less safe. Case in point is the 2024 Whipple tune.
Jasonb543
Detroit
Jason
1993 fox
Why do you say that? Because it’s adding in more spark?
Or because it can make too much power?
engineermike
La
2018 GTPP A10
Some tunes, like the 2024 Whipple, float the timing while riding the knock response. This means wot knock happens every time unless you’ve added quite a lot of octane. It’s safer to knock at 17 deg timing than at 21 because the cylinder pressures are lower at the time when knock occurs.
slime_bullet
Louisiana
Brett
2015 Mustang GT
I run 93 on my gen 5 whipple and gen2 coyote, adding enough boostane professional to get to 95 just for added protection. I think it's a tad over 2 ounces per tank
Angrey
Coral Gables
2016 GT350
It's a very dangerous way to live life. Briefs well on paper, but if the KS malfunctions in any way, it's bye bye motor time.
engineermike
La
2018 GTPP A10
Not just that but in order for the knock retard to work, knock has to happen. Knock always causes damage.
