Undercarriage rattle - need help tracking down metallic rattle on throttle
jaygt350r
California
Justin
2019 GT350R
2019 Shelby GT350R
~ 14,000 miles
Factory exhaust
A metallic rattle comes from underneath the vehicle seemingly after the exhaust and vehicle are at operating temperature ~ 190 deg.
I've been reviewing threads about exhaust hangers breaking and 02 sensors coming lose from the factory exhaust. Visual inspection does not show any of these issues.
If anyone has heard a similar metallic rattle, I would appreciate the feedback or anecdotes. Video attached via Google Drive, thanks!
sk47
North Eastern TN
Jeff
Hello; Could hear the rattle only slightly. I will figure you have checked to see if the exhaust is hitting anywhere and have not found such. What I have found is if there is a heat shield on a catalytic converter, that can rattle. Had such on my Sentra. The rivets/ pins which held that shield in place had become loose.
I found some heat-resistant material left over from doing a job on an oil furnace. stuffed it between the Cat & the shield. Stopped the rattle. Another possible thing might be rock wool/mineral woold insulation. Or maybe something used on a wood stove.
This said i do not know if your car has such a shield.
Good luck
jaygt350r
jaygt350r
California
Justin
2019 GT350R
I really appreciate the response, and i'm going to check over all the things you mentioned. Thank you.
2019 Shelby GT350R
~ 14,000 miles
Factory exhaust
Check the emergency brake cable and attaching assembly found under the driver side trans tunnel. This has been a known source of tick/rattle as well and is hard to replicate unless in a certain RPM range. When the cable is loose, it vibrates or raps against the trans tunnel under certain conditions OR could be touching exhaust mid pipe. How to adjust the cable and assembly:
https://www.mustang6g.com/forums/threads/how-to-adjust-your-parking-brake.25204/
If that was not the source of the noise, then also check:
Check the trans block spacer plate, it’s a common issue across the S550 and F150 platform:
https://www.mustang6g.com/forums/threads/engine-transmission-plate-noise-fix.115718/
https://www.mustang6g.com/forums/th...hen-accelerating-hard-above-4000k-rpm.107728/
Check the driveshaft center support bearing assembly. There is a small aluminum plate attached to the bottom of it which comes loose and rattles - see this thread:
https://www.mustang6g.com/forums/threads/identify-this-metallic-rattle-🙏.161210/#post-3455184
jaygt350r
jaygt350r
California
Justin
2019 GT350R
Thanks for all this info, appreciate the response. Going to throw the car up today and have a look at all that is referenced here.
tampasnake
Tampa, Florida
Shelby GT350R
The rear most muffler hanger bolts on my car sometimes vibrate slightly loose and I get a rattle on my car.
Gray Area GT350
Minnesota
Brad
2017 GT350, 2013 Boss 302
Not sure if Ford had a later fix than my 2017 but my similar rattle was the sheet metal plate between the engine and transmission. I cut a piece of insulated aluminum matt to fit the exposed plate and that solved the problem.
