Tuner Can't Tune Car
tdstuart
tdstuart
Arizona
Triston
2015 Mustang Gt Premium
What type of sealant did you use ?
Permeatex Thread Sealant High Temperature 59214
Just had some laying around. Would have put some thread sealant tape on it but I was worried that the extra force would damage the threads as they are just plastic threads on the piping itself.
tdstuart
tdstuart
Arizona
Triston
Your trims are good now?
No trims on the Lund tune are good but they have always been good. I have been using the Lund tunes whenever I need to drive the car. They are for my old JLT intake but the maf diameters are close enough to where it works.
What I was saying is that I didn’t see any change in fuel trims on the Lund tune so I know there likely wasn’t any leak throwing my tuner off.
GregO
Illinois
S550 GTPP
Don't use anaerobic thread sealer/locker on plastic components. That type of sealer/thread locker will destroy plastic in a matter of days.
Permatex High Temperature Thread Sealant is a medium
strength anaerobic sealant with PTFE for tapered pipe threads.
This sealing compound is of a white, creamy paste
consistency. The high lubricating properties of this compound
prevents galling on pipe threads and fittings. It will provide
immediate low pressure sealing and allow for the readjustment
of fittings shortly after assembly. After 72 hours the joint is
sealed to pipe burst pressure. This product has a medium
solvent resistance and will withstand temperatures to 400F
(204C). This product is not recommended for use on
plastic piping.
tdstuart
tdstuart
Arizona
Triston
plastic piping.
Damn good catch. Is there any you know off the top of your head that would work? Like I said I would just use thread sealant tape but I’m worried the force will just destroy the like 3 plastic threads
GregO
Illinois
S550 GTPP
Yes, there are specific plastic thread lockers by the major brands.
Search around.
Locktite 425 is designed for metal to plastic.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Lunds tune has good trims but none of the other tuners have good trims?
Same CAI and injectors?
Am I understanding this correctly?
Whitedevil95
Temecula, CA
J.P.
2017 Mustang GT
I had to go back to the start and figure this out too. Looks like his motor was rebuilt by himself and now on the same Lund tune it was on before it is slower, Lund says tuning wise all looks good, OP doesnt believe there are mechanical issues with car and Lund isnt giving him proper customer service so is finding a new tuner to make it as fast as it used to be before the motor went.
tdstuart
tdstuart
Arizona
Triston
Only correction is I think there is something mechanically wrong with the car but I’m hoping a competent tuner may be able to help me figure it out or narrow down the possibilities.
Lund sent me the same tune just rebuilt and car would run 1-2 seconds slower 60-130 and they just said idk it’s your issue. When I pull up the datalogs it’s clear the cam timings are completely different. Just gives me no faith in them to take me seriously or put in more than 2 seconds of effort.
tdstuart
tdstuart
Arizona
Triston
Lund was made for JLT but works fine for my new PMAS. Don’t like Lund so wanted to get a new tuner and new cai was a good excuse. Got the new cai and new tuner. New tuner couldn’t tune the car. I tried the old Lund tunes and fuel trims are basically spot on so I’ve been running those until I get a new tune that runs right
Whitedevil95
Temecula, CA
J.P.
2017 Mustang GT
Not trying to be a dick here so bear with me. But where did you learn how to read cam phasing and timing? How do you know the data you are looking at is wrong or incorrect in some way? These cars have Twin Independent cam phasing that allows them to make changes in real time with varying and multiple inputs im not sure that you would be able to read a log and say something was off like that.
K4fxd
NKY
I'm going to look at the MAF period numbers and see if they fit that intake. Hopefully today.
I'm assuming the fuel trims are what is out on the non-Lund tunes? Correct?
I only glanced at your logs but the cam timing looked good for your comp cams from Lund. They were stock from the other tuner you sent logs for.
I haven't looked at all the logs you sent so I may not see the discrepancy from Lund yet.
GregO
Illinois
S550 GTPP
I don't see how it's possible PMAS and JLT share the same transfer functions.
There's more to it than the 120MM MAF diameter.
tdstuart
tdstuart
Arizona
Triston
No it’s a good question. When going wot the cams shaft phasers (should) do the same thing consistently based on rpm. So I can look at the graphs of how much each phaser is adding or retarding during the pull. It’s normal for them to fluctuate a small bit but it’s pretty noticeable when they are doing completely different things. So I can look at a log of one tune and a log of another tune and see if the cam phasers are set to do the same thing or different. I don’t remember how different they were but it was a pretty noticeable amount that should have stood out if they were comparing logs.
