To Those Who Have .. Subframe & Alignment
Blu22HPP
Blu22HPP
Minnesota
22 Ford Mustang Ecoboost Premium HPP
I use a local Firestone shop for alignments and they do a great job. I purchased a lifetime alignment figuring that it will eventually pay for itself. Some say that Firestone is no good and others have good experience with them.
That's where I went today.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Blu22HPP
Blu22HPP
Minnesota
It's the camber, look at your rear specs.
One thing to note about that is, I thought -1.5 was the sweet spot? Seeing the -1.6, keeps it not so tucked. I imagine that -1.5 pertains more the OEM set up vs the flush look. I see many are somewhere between that and -2.0
K4fxd
NKY
I hear he books up a week or two out, but if he can do it, I'll glady wait.
I have a good alignment guy here, well worth the wait. I just time any major suspension work so I'm done the night before my appointment. He gets everything exact side to side. It's painful to watch, so I don't anymore.
RAVAGE88
CT
'21 GT Premium
That's quite a list!
Seems definitely the way to go. I see many seem to have had success with this option. The one thing that has got somewhat in my way is, if you square the rear, how about the front?
The idea is to set your suspension up from a solid point of reference. Given the process used to originally place the subframe, it's an easy assumption that the subframe isn't positioned correctly....some very simple measurements can validate this. Although, based on your alignment numbers, the math isn't difficult to understand what it would mean to correct the camber, but does this mean you'll no longer see a difference side-to-side? No, it likely means the issue now shifted to someplace else.
If you properly dowel locate the subframe, which zero's your point of reference and then base your alignment on a centered subframe, you'll be far better off in the long run. And, having an overly active OCD issue myself, I can tell you that you'll be tons more satisfied than doing the bare minimum to reach a point that you believe all the issues are resolved but in reality, have fallen considerably short of proper execution.
MB
shogun32
Northern VA
Blu22HPP
Blu22HPP
Minnesota
I guess that is my reason for this thread. Essentially finding the proper course of action. I'm not looking to take short cuts and definitely want to do it correctly. If this is simply an alignment correction, then the rest is unnecessary. However, if correcting the subframe is what it takes to do this correctly, then I'm fine with that as well. I believe a proper foundation is important, especially if / when I plan on doing other things down the road.
RAVAGE88
CT
'21 GT Premium
I think that combo is a first.
Not sure, but once dialed in, handles better than anything I've built prior. Dropped my car 1.25".
Do you have a cheap source? Because that BoM racks up real fast.
Unfortunately, I don't, and you're 100% correct....the BoM gets ridiculous really quickly. I buy parts over a period of time and stage them until I'm ready to do a huge chunk of work. One can't do the 350R Brake Kit without also doing new wheels, which means new tires, and why keep the OE bushings that come in the new knuckles when it makes sense to go spherical and on and on. I'll also do the Mach 1 Knuckles and Hubs in the front, but everything else for the front is already in place. When I'm done underneath, there won't be anything left that's stock for a GT. Someone started a thread recently about getting bored with a GT, but I haven't hit that point yet.
MB
RAVAGE88
CT
'21 GT Premium
Exactly, and when you mentioned your OCD, I knew what I was dealing with :cwl: .
However, "correctly" is relative, as it depends on what you want to do with your car. I'd never expect anyone to go as far as I'm going with mine, but because I already dealt with what you've mentioned, I highly recommend dowel locating the sub-frame as part of what it means to properly align the car. All the other stuff that I've mentioned is just me, as my car is not a daily. If you want to deal with wheel hop issues, make sure you can launch the car, or want it to handle well on the track, all the other stuff becomes part of "correctly."
MB
K4fxd
NKY
WOW and he advertises as the alignment guy???
Racer5973
Fayetteville, NC
ray
2017 mustang gt
I thought I would start my own thread as I originally piggy backed off an older one. I'm looking for input from those who have and those who have chosen not too. Please bear with me.
About a week ago I had my new wheel & tire combination installed. The goal was to move on from the tucked look, and move more towards the flush, but still remain inside the fender (19X9.5, 33 offset, 265/40 19).
Seeing how alot of others in here have gone with much wider setups and still remain flush, I thought this would be a non issue.
Apparently, my car has the same issue as many others have experienced, one side sticking further out then the other. Right side, slight poke while left side tucked in. The very thing I was trying to avoid by choosing this option.
I have read through the forums to find options to correct this issue, such as Steeda IRS alignment kit (which I have ordered). I've also seen several lockout kit options as well options to support the IRS.
My goal with this car was to essentially tweak it or maybe fine tune it if you will, not transform it into something else entirely.
I have had the alignment checked and will share that along with pics of the left and right side.
I measured the distance from fender to top of center cap ridge on both sides using a plum bob, to see how much difference there was. The passenger rear, measured at 2 1/16 inch vs drivers side 2 1/4 inch. Obviously tucked in, this is not seen. Honestly the difference seems like it shouldn't matter. But what about when you add your alignment into the equation? The difference on each side could make it appear worse.
For me, unfortunately it's the OCD coming into play.
Before I start diving into the possible rabbit hole, I would like get input from those who have gone this direction or from those who have chosen not to. Going through the forums I have come across some that have worked and some that haven't, as well reasons not to.
Thank you for your time.
Get the camber adjusted that is your problem!
Blu22HPP
Blu22HPP
Minnesota
That's what I'm going to start with, but finding someone to do it has become a bigger challenge than I thought.
