Steeda subframe alignment kit
tj@steeda
Timothy
Hello All:
I wanted to pass along a great how to install video on the Steeda Subframe Alignment Kits:
[ame="[MEDIA=youtube]fi1-r55Yvgk[/MEDIA]"]
With the holidays right around the corner ... & that means sales will start popping up ... what a gift to put on your list to help align the subframe to the chassis!
Check out the link above to see what others are saying.
Best Regards,
TJ
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
Sooo.. you install this $40 kit and then have the IRS aligned? By who? Same people that do wheel alignments?
Yes, If you have any questions give Rod a call @954-960-0774.
He is at our S Florida location.
Mike D
SolarFlare
S. Fla
2015 CO GT
Mike D
Do they install the kit and align the cradle at this location?
tj@steeda
Timothy
Yes, our Pompano Beach, FL location can handle that, with alignment & much, much, more.
We have springs/shocks & struts on sale too - could be worthwhile to get them all done a once!
Best Regards,
TJ
SolarFlare
S. Fla
2015 CO GT
Best Regards,
TJ
Yea it would make sense now but I'be gathered a blower kit I need to install. But it will be next up.
tj@steeda
Timothy
We can install the blower kit too :)
TJ
RedfireV8
Louisiana
2019 GT PP1 A10
Maybe I'm "underthinking" how simple this is but can't you just do one bolt/hole (bolt hole, lols...) at a time and not worry about messing with the alignment as well as making it much easier installation wise?
Will be installing these this weekend is what has my curiosity peaked.
SolarFlare
S. Fla
2015 CO GT
tj@steeda
Timothy
No problem, we just offer peace of mind that it will be done right. If you end of wanting it done, just give us a ring at 1800 950 0774.
Best Regards,
TJ
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
"Over-thinking" as an engineer, I can visualize that you can look at the alignment of each pair of holes when you take out a bolt. Technically, you would have to replace that bolt and then remove each of the other 3 in succession. The more aligned the holes are now, the less likely you would need a new wheel alignment.
Imagine a pair of holes is misaligned 1/4", and then you align it perfectly during the kit install. That puts the wheel angle out even more, because of the angle amplification. (The wheel is further from the car centerline than is the cradle bolt.) So you would need an alignment. Not to the degree that your first drive should be to get the alignment, but you get the idea.
tj@steeda
Timothy
Hello All:
We are now live with our Black Friday Sale!
Please visit us at www.steeda.com
Best Regards,
TJ
monkeyboy
Los Angeles
2004 Ford F350 2013 Fiat Abarth 500
You could probably do that but from what I have been seeing some of the cars aren't aligned real well from the factory. Resetting it back to sloppy doesn't help.
t4zalews
Royal Oak, MI
2015 Mustang GT PP
Put in a set of lowering springs yesterday and decided to put in the subframe bushing support system and alignment rods while I was there. The Subframe bolts on the left side went in like normal, the right side not so much..with the alignment rods in they were off by around half an inch. I just left them out and finished tightening everything up.
Only had two jacks so I did the left side first..then the right. Do I have to put the whole car up and then loosen all four subframe bolts for the frame to line up on both sides? Can I just jack up the back of the car?
