EFI
- May 19, 2015
- Masshole central
- 5.Br0
The C&R cooler is a direct replacement for your existing one, which sits between the radiator and condenser. It should have 0 clearance issue with the towhook as it's nowhere near that. If your OEM cooler didn't have an issue, this won't either.How was installation? The only thing I can maybe see that might interfere with mine is that I have the ZL1 tow hook on my car that could get in the way.
And while I didn't do the install, I think it's pretty easy once you take the radiator out. I swapped the radiator for something bigger, and when it was out I had a clear shot at the trans cooler and lines. It would have taken an extra 2 minutes to unhook the OEM unit and plug in the new one since it uses all the factory lines and connections.
