16s550
Thanks brotha... I'm gonna go with these. I loved tsp when I had my camaro back in the day.These are thicker stainless which will sound better. Both will perform the same. These cost less.
I think I read somewhere that it's a benefit for flex fuel cars? I'd be interested aswell to know.Do these headers put the O2 sensors at a downward angle?
All 1 7/8" long tubes like these will perform within a couple hp of each other regardless of brand.Performance wise how do these compare to Stainless Works?
I want to pull the trigger soon on some LTs.
Yeah I figured that. Do you have this header?All 1 7/8" long tubes like these will perform within a couple hp of each other regardless of brand.
Thats not exactly true. Certain designs once blowers are introduced the limitations become apparent.All 1 7/8" long tubes like these will perform within a couple hp of each other regardless of brand.
Let me know when you install them! What catback are you running? I'm close to the bay area might just have to hear it in person before I pull the trigger on those headersTsp has been in the game a long time and make lots of great parts I trust them and can't wait to Install mine.
Borla sport. Yea if you want to come down you are more than welcome.. should have them on next week waiting for shop to have time to.get me in.Let me know when you install them! What catback are you running? I'm close to the bay area might just have to hear it in person before I pull the trigger on those headers![]()
I disagree on the performance aspect here as we are comparing all same primary and collector size. Sound is effected mostly by tubing thickness (length and size are all very close here) and in this case the TSP headers are thicker wall than others at 2mm. These and my OBX headers look to be designed like SW/SP headers in fact there is a good chance they are made in the same factory overseas as SP headers. Pipes are same size (1 7/8") roughly the same length (cars chassis dictates this mostly) and look to be plumbed into the collectors the same way. ARH are plumbed differently and don't have welds along the bends but that doesn't seem to make much difference performance wise. Terry dynoed SW vs ARH with virtually identical results.Thats not exactly true. Certain designs once blowers are introduced the limitations become apparent.
Header design also impacts the quality of how your exhaust sounds
Like i said, once a blower is involved thats isnt true . Also if you dont think design (routing and lengths of pipes) affects flow at different cfm levels you need to take some fluid dynamic classes. The routing of the piping, not just thinkness affects exhaust note. A perfect example is hypermotives video showing that arh headers cleaned up the sound of Shawns corsa sport catback that was using sw, it got louder and crisper. Header design most definitely changes exhaust tone.I disagree on the performance aspect here as we are comparing all same primary and collector size. Sound is effected mostly by tubing thickness (length and size are all very close here) and in this case the TSP headers are thicker wall than others at 2mm. These and my OBX headers look to be designed like SW/SP headers in fact there is a good chance they are made in the same factory overseas as SP headers. Pipes are same size (1 7/8") roughly the same length (cars chassis dictates this mostly) and look to be plumbed into the collectors the same way. ARH are plumbed differently and don't have welds along the bends but that doesn't seem to make much difference performance wise. Terry dynoed SW vs ARH with virtually identical results.
http://www.mustang6g.com/forums/showthread.php?t=18140
