Side by Side header test, same car same day! SW & ARH!
beefcake
Bethel
2018 Ford Mustang
Got an opportunity to do a nice side by side comparison of a couple of the more popular headers last night.
We did a before and after with the Stainless Works 2015 Mustang GT Headers in performance connect, and an ARH bottleneck system. We had also planned on doing a Kooks system as well and they were def up for it, but with time constraints with getting ready for nmra next week, we knew we’d only have time to do too.
First, we have a lot of classes we have competed in the NMRA series over the last few years. Coyote Modified, Coyote Stock, Pure Street, Factory Stock, Super Stang.
We have tried and used all 3 brands, and have always been happy with all of them. We sell and install all 3 brands, and have never had issues with any of them as far as fitment and quality. All are USA made and have lifetime warranties.
Onto the 2 we tested last night.
Visually both are very good quality, great welds.
In the Box – Stainless Works
The Stainless works comes with the Headers, bolts, and extensions (they didn’t originally, but now they do as fitment on the 15 is different than previous coyotes where they weren’t needed.
On the auto car, we did not need extensions, there was enough room for the 02’s to fit.
The SW does not come with a mid pipe, they have 2 versions, a factory connect which meats at the 2 bolt connection clamp, and a performance connect, which will bolt a full 3” to their catback. These could be made to work with most catbacks into a full 3”, but would take fabrication.
The stainless works price point for headers alone is less expensive, but they do not come with a mid pipe like the ARH does. If your doing a catback this doesn’t matter, but if you are only planning on axle backs / stock mufflers, this might be something to consider.
In the Box – ARH
The ARH headers come with the Headers, bolts, extensions, and also a small bracket to keep the a/c line away from the headers. This is actually a nice little bracket. When removing the SW headers that were installed a few weeks back, we noticed some black coating from the wrap around on the a/c line burnt onto the headers. This bracket will prevent that in the ARH system. – We liked that.
02 Extensions were needed on the driver side on the auto car.
The ARH comes in 2 configurations, they have a full system that is their headers and their exhaust. Their non exhaust system, which they call the bottle neck eliminator comes with the headers, but they also come with your choice of an X or H pipe as well that eliminates the factor “big can”, that everyone dislikes.
The ARH price point is higher than the SW, but as mentioned, if you are only planning on doing axle backs or keeping the stock system, this could be an important decision, as most want to delete that resonator. If your doing a full catback, you may be paying for an x or h twice, so this might be something to consider.
Installation
Both systems are easier to get on and off compared to previous year coyotes, since you don’t have a big k member in your way.
With a 2 man team, we were able to get the SW system on when we did it probably 20-30 minutes quicker. The SW system went on and off using all the factory studs. We did have to remove 3 studs on the passenger side and reinstall to get the headers on and off.
With the ARH we did need to use bolts in some of the holes due to the configuration of the system. Nothing wrong with this at all, but some of the positioning was a little tougher to get to for tightenging. Nothing that would change a decision on either system.
On the SW, the tougher side is the passenger side.
On the ARH, the tougher side is the driver side.
This is mainly due to how each system routes the tubes. It was interesting to see them side by side and see that each mfg chose a different position for their tubes into the collector. Meaning that if you look into the collector, where one may have had cylinder 5 at the top left, the other may have been top right. That really made us curious on the power aspect of things. Why the difference we wondered?
The ARH headers themselves are the longest, while the SW are slightly shorter to the collector. (for note, the kooks will be the shortest as technically they are more mid length, but we’ve never had an issue making power that said.)
For comparison on the dyno, we unbolted the cat back and left the SW H pipe on as we wanted it to be a fair comparison. We thought we had an H pipe ARH system as well, so we thought that would be a perfect comparison. We ended up with an X pipe ARH system, in our experience an x is worth 2 or 3 over an h, but nothing crazy, so we were still fine with it. We probably would have unbolted before the midpipe, but no biggie as again, only a couple.
As far as the dyno numbers, our auto car has no jlt with plans for the blower going on starting today. The SW system was already in place so we made a couple runs to get the car up to temp and then made 2 pulls. The auto is a little tricky rolling and and keeping the converter locked. The 2nd pull on the SW it didn’t lock til late in the pull.
We did the swap and was back on the dyno 4 hours later. I don’t think you’ll get a better comparison than that. As far as the low rpm, don’t get too hung up as again, we were rolling into the converter. You’ll see one very solid locked pull on each, one where the arh was a little later, and one where the sw was towards the end.
Anyway, here are the results.!!
Looks like on a side by side, both systems perform very well.
Both are great quality, both seem to make very similar power, and both are a great choice.
I think the biggest determining factor for choosing a system, is going to come down to the mid pipe / resonator delete as we mentioned in the comments above.
Thanks to Nick and the guys at ARH for a great quality product and the same to George and the crew at SW. We had a couple extra guys hanging around very anxious to see the numbers on the pulls!!!
ATTFighter
Awesome! This should settle all the banter about ARH headers making more power than the SW headers. I would run either or in my car, both excellent products. Beef, for those of us with sw headers should we be concerned about our AC line over time? Seems like an expensive fix.
ronnies_mustang_5o
Paris, TX
2015 Race Red GT Premium Perfomance Pack
Beef, you really did come through on this, I'm impressed. Having installed ARH on my 2011 Hemi and now SW on my 2015 5.0, I know you went through a lot of work to do this and I really appreciate it. You came through on the SW catback dyno and you've done it again.
I have a full SW catback & headers on my car and there's always been a nagging feeling in the back of my mind that I chose a system that made less power than it should be making. Especially with all the SW drama. Now my mind is at ease knowing I didn't waste $1,200 and 5 1/2 painful hours of installation on a subpar system.
I love ARH, top notch! The quality in SW is also excellent, with the exception of the drone. All in all, can't really go wrong with header brand when it comes to their longtube offerings for the 2015+ Mustangs IMO.
beefcake
beefcake
Bethel
2018 Ford Mustang
I'm not sure over time, but the fact we had the material melted on the header is of concern to me. I would do something to keep it away from the header.
it's a simple fix but I would do it. I like the fact that arh had the time to think about that so we wouldn't have to. had we not done the header test I don't know that we would have even seen it for a long time
beefcake
beefcake
Bethel
2018 Ford Mustang
as a vendor I'm not here just to sell I want to feel comfortable about what I'm selling and I want my customers to get the best that they can get.
if one had made more power than another I would not have hesitated to report it.
people think I'm biased towards the sw, because they are on the 2011 car. people forget that we have 3 other race cars that have a aRH on them and another with kooks on them.
anotherneon
15' base GT w/3.55s
It's just that customers numbers are showing otherwise and that has me scratching my head. There was a local guy today who made 448/416 with ARH on the same dyno that their shop car made 450 with ARH and the same dyno that barrel made 420 with SW all with the same tuner and mods aside from the exhaust. However this test will keep me quiet about the topic thank for doing the test:thumbsup:
stoli
Fat Guy Racing
Lakeland, FL
'15 Black GT/PP
Thanks for taking the time to do this test Beef - much appreciated!
Barrel
Hoonigan
Cars and Trucks
Thanks for getting this done. I guess we can all shut up about it now.
beefcake
beefcake
Bethel
2018 Ford Mustang
Nice post!
Whats going on with the dynos in the lower RPM's?
(Even with the smoothing on 5, thats pretty wild)
Rolling into the car trying to keep the converter from not locking
the 11 to 12 we had to do Dyno lock files to make them work
the 13 to 14 cars with select shift we rarely had issues with the converter not locking on the dyno
the 15 is being very finicky we may start doing Dyno locked files again
again every car is different look at what our car makes
I guarantee I can run with any of those 440 rwhp cars
beefcake
beefcake
Bethel
2018 Ford Mustang
I just want some sleep I only had 4 hours the night before and doing this test I only got 4 hours last night lol
at the end of the day I'm glad we have a few nice USA made companies that put in a great effort on their product
actually four with Dynatech but we have never tested their product and they don't have any mid pipe for the 15 yet
Farmundeh
Astoria, NY
Magnetic 2015 GT Premium
Awesome work Beef. Thanks for this.
BathS550
Maine
2015 Mustang GT - 50th with PP
You deserve much ass patting for this.
