street/track brake pad
thornclaw
northbrook, il
2015 mustang gt
for a mixed use brake pad there seems to be no good option. one possible solution would be to mix pads. for example, have the inner pad on one caliper be the gloc gs1 that is a street pad, and have the outer pad on the caliper be a gloc r8. potentially you would have the best of both worlds.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Hahah, no, thats the worst of both worlds. Your street pad would do street oad things at the tracl and the track pad would do track pad things on the street.
just swap them, it takes a couple minutes but you should be in there bleeding fresh fluid to the calipers before your track days anyway.
Optimum Performance
Gold Sponsor
Titusville, Florida
www.facebook.com
Tommy
'15 GT PP
Or just run R10 fronts and R8 rears all the time and have very good street manners and still pull over 1.4g's in braking with a mild street tire.
It would be extremely bad to have different COF pads on the same rotor, not to mention the same end of the car. You would be attempting to slow down one side of the rotor at a different rate than the other connected side. Also the temperature delta one side to the other would be so great you would be asking A LOT from the materials of the rotor.
Pretty sure your ABS module would just burst into flames trying to figure out what is happening šŸ˜†
thornclaw
northbrook, il
2015 mustang gt
the r8 has a minimum temp of 75degrees. in the midwest freezing temperatures that wouldnt work well. the combo of gs1 and r 10 would give a reasonable mu from zero to 1500 degrees. no single pad on earth could cover that range. the friction curve of that combo would be an exaggerated bell curve, but wouldnt be an off/on phenomenon. yes, the rotor would heat unevenly but im not sure how big of a problem that would be. the rotor would also wear unevenly. the abs shouldnt be affected. i feel there should be some real world testing of this concept prior to it being dismissed. the idea would be one set up that could handle a wide range of uses- for people that track only occasionally. also, you could put the r10 on the inside position to minimize dust.
Howitzer
NC
flickr.com
Howie
2015 Mustang GT, 2000 Mercedes C280
This is close to what I'm running. R12 front / R10 rear. Brake dust and noise on slow stops is insane. I'm definitely going to to be getting a street pad for non-track use to keep my sanity.
In terms of this thread, it sounds like a terrible idea to mix pad material on the same rotor...if that's what I'm reading? That sounds crazy for the reasons already stated.
illtal
Never heard of it being done on the same rotor, but someone would need to test the performance aspect of it. If you're worried about uneven wear, I think that the least of the worries when you're taking a car to the track. A rotor then becomes a true wear item anyway.
Flyhalf
CA
www.youtube.com
Alessandro
Mustang GT 18 10speed auto PP1 , GT500 '21
The G Loc pads (and carbotech) are not the best for dual usage because they are extremely dusty and when u brake it seems you're killing a cow.
There are great options how there.
Counterspace garage (CSG) is what i use in my racecar.
But when i use the car in the street they are phenomenal and no noise.
They are on expensive side but they last A LOT.
And hella brake power .
Alternative are the DCT 60 or 70 by hawk. OR dsuno by ferodo
NightmareMoon
Well tons of us have real world experience with GS1 pads on the track (they glaze quickly and then don't slow you down nearly enough), and tons of us also have experience running track pads on the street (first stop can suck at low temps and they dust like mad, and often squeal badly).
Individually the pads are not able to handle anything outside the range of uses they normally handle. You have not blended the compounds. The system can't be averaged out and treated as a whole.
The pads are acting individually, so you get the problems of both pads and a middling amount of braking force which is worse than using the correct pad for the correct use. Braking force would be an average of the two pads, but neither the street or track pads will operated well when used outside their range of temperatures, so the result will be inferior.
There's no silver bullet for this. Our cars are very very heavy and when you need a track pad, you need a track pad.
thornclaw
northbrook, il
2015 mustang gt
i respect and appreciate the input from the above members. certainly with brakes, caution is of paramount importance. however, i think my point is best illustrated with 2 simple questions:
1)would a gs1/r10 combo have better braking than an an r10 only setup on the street?
2)would a gs1/r10 combo have better braking than a gs1 only setup on track?
i think the answer to both would probably be ā€˜yes’
Optimum Performance
Gold Sponsor
Titusville, Florida
www.facebook.com
Tommy
'15 GT PP
The answer would be no, this is not how any of this works.
tosha
Canada
Mustang GT PP1
Please don't take this personally, but both options are idiotic. It's all backwards - gs1 is not designed for track and r10 is not recommended for street. If you don't want to swap pads (which is not a big deal if you swap wheels anyways and already have car in the air), then cash out for something like pagid rsl29.
thornclaw
northbrook, il
2015 mustang gt
ok
i will yield here
however, my quest for the lazy man’s solution to this problem continues.
stay tuned
