pumxee
I already have an amp hooked up using an LOC which I tapped into for the rear speakers. I also have a sub amped in the rear too.Not enough info... Are you just replacing the stock speakers with better ones? Are you adding an amp? Are you using LOC's with an amp? Are you planning on using stock speaker wiring? There are too many options.
Tell us a little more about what you're doing.
For the front I would like to replace the factory speakers and tweeters with the hertz HSK 165 system. I would like to reuse the factory wiring. atleast for the door and I could run new wire to the tweeter (since I have to use a cross over anyway). But, my question is really simple..... Where do I tap into the front speaker wiring where they havent been split to go into the tweeter... Besides right behind the dash unit...
Is the driver side kick panel wiring a suitable location?
