Stereo Information (Wiring, Upgrades, etc...)
rambunctious
Holland, Michigan
1930 Model A 50's hotrod, 2011 Diesel Superduty
Anc +\- left and right are the noise cancellation and the sound synthesis signals for the front channels. A third anc +\- is a mono anc/sound synthesis signal fir the rear.
These are licated in the left most cinnector at the factory amp.
You will want to ignore these for your upgrade because the new gain of your aftermarket setup will exaggerate this sound and be two loud.
I am still confirming the other oair of cinnectors that feed audio signals. But they are called out by Rhino... And others
Hope this helps
Ramb
Quiksilver15
Houston
2015 Ingot Silver GT
Anybody ever figure out how to add that connector in to make a factory sub work with a 9 speaker system? Could that be a tail light harness? Maybe it only powers the taillights, rear speakers, trunk light and sub? If it wasn't expensive I could easily replace that harness.
Just purchased a factory 401A sub enclosure. Has anyone figured out how to add it to the 9 speaker stereo that is included on the premium?
Also can anyone confirm that this is the connection needed for the amplifier bolted to the back of the box.
http://www.ebay.com/itm/Speaker-Con...ash=item25b6191e47:g:iLAAAOSwXshWs~FM&vxp=mtr
ktp1598
Mount Washington, Ky
Bobby
2019 Kona Blue California Special
Never figured it out. Looks like it's wired into a rather large harness. It's likely the BCM will have the power to it shut off anyway. I finally gave up and wired in a smoke prone Infinity powered sub. It sounds great and stays put for $162.
Quiksilver15
Houston
I have a little 300 watt amp in storage, I'll probably just wire it up and get a new 8" sub. Only paid $100 for the whole enclosure with sub, amp, and bracket. So I'm not out much.
Techno
Stuart,FL
2017 GTCS
Does anyone know if the center dash speaker is a full range sum of both left and right? I want to use it to drive an infinity base link.
ohbuckeyes
Cincinnati
2015 Ecoboost Premium
Could someone post a picture as to where you are jumping into to get the remote turn on access for the amp? I have the ground wired, LOC wired, power wire ran, just waiting on the remote wire as far as how to run it, or where to run it to.
Techno
Stuart,FL
2017 GTCS
the initial post said this, does it help?
"12v Remote Turn-on Lead
There is one conveniently located in the trunk wiring harness near the right rear speaker. The wire you are looking for is the blue/white one."
ohbuckeyes
Cincinnati
I searched for it and didn't see anything. A pic would be great though.
s550stprmtrooper
s550StormTrooper
Royal Palm Beach, FL
James
2016 Oxford White GT
DEI Wiring diagram
This might help some of you too
chut
San Antonio, TX.
'15 Mustang GT, Performance PKG, Six Speed Manual
Dude!,
I don't care what anyone else says, you're beautiful to me!
Thanks for the wiring chart!
QUOTE=s550stprmtrooper;1103559]This might help some of you too[/QUOTE]
Gn n 60
San Diego
Dylan
2015 Mustang Ecoboost PP Convertible
The 6.5" Pioneers I bought for my 201A didn't fit at all. Plus, the factory speakers had more bass :doh: Is it possible to just buy a 10" sub and wire it using the existing wiring for the 8" in the back??
In other words, what is the cheapest, quickest way to have a more powerful low end?
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
Replace them with shallow subwoofers like [MENTION=15347]ForTehNguyen[/MENTION] thread. You will need adapter plates, but the small deck hole does not degrade sound quality at bass frequencies anyway. You will need a low-pass filtered amp. I predict that a total impedance load of 4-8 ohms will out-perform a 2ohm load.
You may also need high-to-low level converter cables.
All this assumes that the signal sent to the deck speakers is not high-pass filtered. My acoustic measurements last weekend left me inconclusive on this.
ForTehNguyen
Houston, Texas
15 GT
all I used were spacers with speaker tape to under mount them. Mine were dual 4ohm coils wired in parallel to get 2ohm for 100W output
jasonstang
Denver, CO
2017 GB GT/CS 6MT
Just bought a factory sub, will not work on my 9 speaker setup. Missing factory connector. Had the original owner send a pic of his car 12 speaker setup and he has the harness while on my car it is missing.
Eddie
Now this sucks. I want to go trade my car in for a different one now.
