Steeda CAI Review and Install Notes:
David@Steeda
United States
www.steeda.com
David
Bolt-on, slammed S197
So... I brought the car to the track today(1/8th mile). I have the No tune version. So far it isnt looking good. DA is 525ft today. And the car is down on power. I have run consistent 88.x mph traps in various DA ranging from 100ft to 1650ftand have also clicked off a couple 89.x runs with stock intake. Best mph so far today is 87.2, with a couple of 86.x runs. The 87.2 run was with filter removed. I wish I had brought my stock intake with me to do a compariso. Same day/DA.. but as of now, indications are that the car has lost power. I will edit this post when I get home and add various timeslips to show mphs
Going to try a couple more runs to see if it improves. .
Hey, I'm sure you're aware that many factors come into play when running your car at the track. If you wanted to do an apples to apples comparison, you should run both the stock intake and an aftermarket CAI the same day with consistent engine temps and IAT for the runs.
SLA
Houston
2016 GT PP
A better 60' time can lower your trap speed. Too many variables for that small of a trap speed change. Headwind, slower shifting, heat soak, ect...
Poppacapp
NC
2015 Mustang GT
Ohh boy, it looks like we have mixed results on this intake. My butt dyno also can't tell the difference other than the engine bay being a little louder.
I am just trying to be as fair as I can. I will try to come back next sunday with stock intake and swap them out at the track to get a true verdict.
Poppacapp
NC
2015 Mustang GT
60ft time is worse. I have pulled 1.85 60ft with stock intake setup. 60s are in 1.90s today. So 60ft hasnt changed much. I DID just get an 89mph run, but it was spinning... which will give a higher trap. I will do a same day comparison my next trip to the track hopefully. Running 8.30s today... my best 1/8th et in similar DA(couole hundred ft difference) was 8.05 with stock intake.
  • Like
Reactions: SLA
Cascadia_302
PNW
2015 RubyRed GT M6 Premium
Could be that your car is still in a bit of re-learn as you mentioned that you didn't pull the neg battery cable during the install.:shrug:
Knight5.0
Project Lightning
Chelsea, Alabama
www.youtube.com
Randy
2017 Mustang GT Premium, PP, 401A
I have a K&N recharge kit around here somewhere. I think it would look better with red filter considering my accents
Poppacapp
NC
2015 Mustang GT
Yeah, I plan to do that next time. I guess with me running 8.05 previously, was wanting that 7.9x bad. I DID manage an 87 and 89mlh run with filter out. Other runs were in the 86,x range. The only thing I can base today on is I have run better with stock intake in worse conditions. Would the stock intake have performed the same today? Possible. I do try to run with IATs below 100 degrees. Most of the time in the 80s from staging lane movements. To be as fair as I can, I will swap out intakes next track trip.
Will the stock snorkle work ok with the stock intake, being cut?
NewTekBuzz
Flint, MI
Tim
2019 velocity blue GT 6M - 2015 Black GT 6M (sold)
Did you guys plug this hole on the box as well? I found a plug and it fit right there so i thought it belows to that hole on the box! True or Wrong?
[MENTION=10893]David@Steeda[/MENTION], can you answer this install question?
Thanks
Jeffy_2010
Missouri
Taylor
2015 gt 6-speed/ performance pack Oxford white
I don't think I plugged mine, just for some info, I did re tighten all of the clamps and modified my grille today to let in more air. I let temps are now any where from 4-9 degrees above ambient
stoli
Fat Guy Racing
Lakeland, FL
'15 Black GT/PP
I have nothing but anecdotal results, but I will say after a couple hundred miles the combination of the Steeda intake and Lund tune is 'smoother' at lower rpm/city driving than either my Airaid/Lund or JLT/Lund. I had submitted tickets to Lund a couple times early on about 'rough' driveability in the 1500-4000rpm range on the JLT setup but the logs were always good and nothing was ever changed. Those issues don't exist now. I couldn't say if it is the intake, the tune, or a combination thereof...but I like the end result.
Next up will be to see what it does at the track and, like my testing between Airaid and JLT, I'll switch between them at the track to try and keep it as objective as possible.
Poppacapp
NC
2015 Mustang GT
Ut oh, hype bubble burst
I wouldn't say that yet. I just have this one day at the track to compare. Ideally, I should swap stock intake/Steeda the same day at the track. I will try to do this next weekend if I can make it to the track.
Would like to really see some before/after dyno sheets from owners. This is a very nice intake. I love the way it looks, and for my car, it will probably gain very good power with a tune and the restrictor removed. Don't read too much right now into my results from today. It's highly possible next time at the track, and the Steeda shows gains over the stock one same day etc. We shall see. :thumbsup:
