stanglife
No way man - you're in Florida, too - so it's in-person or a downgrade to Burger King.Make mine a Ruth's Chris gift card please.![]()
That and historically, tramlining has been an accepted byproduct of certain tires and sometimes, alignments. This is FAR from the first car to ever come with tires that like to tramline and I challenge you to research and find an instance where it's been corrected by the simple addition of a brace.Will be looking forward to your testing results; simply curious as to whether there is any TRUE benefit.
Your points are all spot on, and considering the brace does nothing to affect the geometry of the suspension, so I am a little doubtful of just how much an effect a simple brace can have on the steering... Considering just how wide and sticky these tires are, particularly the Cup 2's, I find it a little hard to see how adding a very minute amount of Chassis stiffness would overcome the contributions made by the massively wide sticky front tires to the effect of tramlining.
Would love for the doubt to be proven wrong though:cheers:
I think you really need the spacers or it will never get tight. One thought would be see if you can get a measurement of the inside wall to inside wall in the area of the bolt hole (on the sub-frame), then grind down the spacer to this dimension.Sorry to Hijack, but I have an install question....
I screwed up and couldn't figure out how to get the spacers installed, so I installed without them. Now I see how to do it, but after removing the brace, I see the subframe got indented and now I can't get the spacers in. I tried to bang them out with a chisel with no luck. Any advice on how to get them in, or is it ok to reinstall without the spacers?
Other than that, install was easy and you can definitely feel the difference, well worth the price
Thanks in advance
You must've driven a 1/4" to the right of your traditional line. :lol:Did my install today and then went for a ride around the back-roads I normally drive. I would say I am pretty impressed. The front end feels more planted, the steering more precise and responsive; the car is now definitely more confidence inspiring. After 9 months ownership, the car is still new to me (~1700 miles) so I'm still learning how it feels. I've complained in the past about the poor steering feel and wishy-washyness in the front end, but, with the addition of this brace, I think there is a significant improvement. Is it a placebo effect? I don't think so; I'm glad I added it.
Wow man. Ignorance actually IS bliss.You must've driven a 1/4" to the right of your traditional line. :lol:
What ignorance?... those are your own words. Lol.Wow man. Ignorance actually IS bliss.
Things that make you go "Hmmm...".Took a ride today and came across the town road crew filling in potholes. Had to drive through the aftermath, which kicked up rocks all over the place, so I scrubbed the tires (quick L to R transitions at maybe 30MPH). I do this often on my way home to clean the tires off as our road also ends up with a lot of rocks and pebbles. I was extremely surprised at the sharpness of the steering with this brace. It really made a big difference to me.
Just a thought: Why does Ford decide to punch holes into this sub-frame member? Bigger holes towards the front and smaller ones towards the rear. Is it they are in bed with the aftermarket? Same goes for the Jacking rails (which I also have). Ford adds tapped holes and inserts with hardware for no reason?
