Spoiler Install Question
vdngo
Iowa
Van
2019 Ford Mustang GT Convertible
Hey guys looking for some guidance and insight… so I want to go with the Shelby GT-H rear spoiler on my 2019 convertible GT. The guys at Shelby said it installs with 3M tape and no bolts… will this be secure enough? Right now I have the OEM “bump” that‘s installed with tape and bolts.
MAGS1
Somewhere in Middle America
2022 Mustang GT
I personally prefer a spoiler that bolts in addition to 3M tape. That said, there are quite a few aftermarket spoilers out there that are only secured by 3M tape. I haven’t heard any stories of spoilers flying off cars but I’m sure there’s potential for issues if it’s not installed properly. I would not get a spoiler that is only secured by 3M tape if you plan to track the car at all either.
22MAVXLT
NC
'22 Mustang GT
As long as you prep the trunk lid correctly, it will be ok. You will have to remove any and all factory glue off the truck that your factory spoiler leaves, then clean with alcohol and lastly use a good adhesion promoter where the new spoiler tape will be.
vdngo
Iowa
Van
Thanks guys… no tracking, but I want it to be solid and no flexing.
NeedForGreen
2019 Mustang GT
I'll second what 22 said. Just prep correctly. I have my side scoops on with just 3m and never had an issue.
dpAtlanta
Atlanta, GA
'19 GT350 (#K2503), '17 Cayman, '24 Bronco Badlands 2-door, '26 Ranger Raptor
I would be afraid to install a spoiler with just 3M tape since Ford bolted mine down to the trunk… Ford probably knew tape would be an issue.
Bolt or go home based on the laws of physics and prior Ford testing.
2016 Mustang GT PP w/ Voodoo
Bolt or go home based on the laws of physics.
The 3Mtape does last ok. Not sure how long before it fails but its kinda a great product. If it falls off, then you know to get one that bolts down next time.
my guess is it will be fine because its mostly cosmetic trim. :p
hlfbkd420
SW 'Merica
Bilbo Hicks
2015 KIA Sorento SXL
I have hopes of one day going over 165mph in my car... 3M tape? I think not.
(but then I don't want a spoiler on my car anyway)
NeedForGreen
2019 Mustang GT
It won't fail if you get real 3m tape, not knock off, the correct size for the project and install it properly. The tape on my side scoops has been up for a few years now and even with some serious wind hitting it while driving they are just as tough as day one. Dirt and water is the most common failure of it so it has to be installed really well without any kinks or gaps to not allow anything under it. Always a good idea to use adhesion promoter.
vdngo
Iowa
Van
Really appreciate the input, guys… I do have the Ford parking lamp curtains and those were also only installed with 3M and they feel pretty solid. I may just wait for the weather to warm up to do the install.
WolfMxbee
Wolf
2019 Ford Mustang Ecoboost, 2005 Ford F-150, 1995
You could, theoretically line up the spoiler to the trunk, tape where the outside lines on the trunk itself of where the spoiler sits, drill a hole through the center section of the trunk and then you can see the hole from the underside, now tape down the spoiler to the trunk and mark the hole with a sharpie to the spoiler with hole you just drilled, coat the new hole with paint, and drill a hole through the spoiler that you marked and put a threaded riv nut on it and boom you got two holes in the center of the spoiler bolted down and the outsides are taped
