Yes.Anyone using it and making over 1k-1100ish whp? Anyone popped one?
What head gasket are you using ?i got a gen3 short block from RPG, havent had issues and 1000 wheel on about 17 PSI. I am going to be making 20 psi once i get my boost controller setup. ill see if it handles but RPG said the block is good for 22-24 PSI. lets see the results, still got warranty too so if something happens its ok
Tnx, the car made 1025whp for a yr on a stock gen2 bottom end but finally let go, if the RPG block can withstand 1150-1200whp. I’ll be ok with that, 1k whp is a handful as is.i got a gen3 short block from RPG, havent had issues and 1000 wheel on about 17 PSI. I am going to be making 20 psi once i get my boost controller setup. ill see if it handles but RPG said the block is good for 22-24 PSI. lets see the results, still got warranty too so if something happens its ok
Warranty?? How do they honor that? So many different variables that can cause a motor to fail. Then you have to trust whatever he says was the problem. I love the warranty option. You spend thousands of dollars on something and it breaks and you have no warranty, you're going to be pissed. I feel like all engine builders should have a warranty. Stand by your product.i got a gen3 short block from RPG, havent had issues and 1000 wheel on about 17 PSI. I am going to be making 20 psi once i get my boost controller setup. ill see if it handles but RPG said the block is good for 22-24 PSI. lets see the results, still got warranty too so if something happens its ok
Warranty?? How do they honor that? So many different variables that can cause a motor to fail. Then you have to trust whatever he says was the problem. There's a guy on here the cracked a gen 3 block. Right on the cylinder wall making around 1000hp
That’s why I’m having him do my long block. Less hands in and on the engine if something happens.Warranty?? How do they honor that? So many different variables that can cause a motor to fail. Then you have to trust whatever he says was the problem. I love the warranty option. You spend thousands of dollars on something and it breaks and you have no warranty, you're going to be pissed. I feel like all engine builders should have a warranty. Stand by your product.
Cool same here.I THINK THE GT500 ONES
I agree but there needs to be a way to know that It was used correctly. I will warranty a engine if it is tuned buy a agreed tuner and anytime you know you will be wot you log a few things. Like temp, oil pressure, lamda those are the big ones. That way I know that it was tuned correct and you didn’t cause the failure. I can’t just hand out a engine and hope that they have common sense. Common sense is not commonWarranty?? How do they honor that? So many different variables that can cause a motor to fail. Then you have to trust whatever he says was the problem. I love the warranty option. You spend thousands of dollars on something and it breaks and you have no warranty, you're going to be pissed. I feel like all engine builders should have a warranty. Stand by your product.
That was my thought process. The aluminator is a cheaper shortblock and probably just as strong as the RPG motor but then I have to have someone install my heads and timing components and cams. Still don't know if I want to upgrade my springs or not.. I'll probably get a valve job and I'll probably have lund tune it. I'll have to ship my heads and cams and timing components to Cali since I live across the country.That’s why I’m having him do my long block. Less hands in and on the engine if something happens.
