Shortblock advice
GuardEcoBeast
AR
Guard 16 Ecoboost
The point is that they are all just as reliable. All are much stronger than stock
I seem to remember a video where John was talking about chains and he said that they were made at the same place, but his chains were heavier and different metals. That video was also a couple years old I believe.
Jackson1320
California
Jaxson
2015 mustang gt
Heavier and stronger than stock. Yes
Rothgray
Pittsburgh
2019 Mustang GT
Absolutely. But every time you take it down the track you know that there’s a chance it’s the last
Seen plenty of "built" engines pop on less power.
cobra199711
N.FL
19 A10 GT
To be honest built engines blow more than stock ones. Most built engines do not have the same attention to detail as factory engines
Do you think the aluminator would be a little better than most “ built engine“ since it’s by Ford. I’ve seen a few builds ones let go and it seems to always result in he said she said and no one wants to assume responsibility. I know you can build one for less but Just for arguments sake, what’s your thought?
Angrey
Coral Gables
2016 GT350
In a word no. Ford products are generally way overpriced. Firstly, the FRPP products aren't max'd out (in terms of the most top notch quality components and elements) secondly, they cost more than what it would cost you to build your own through a custom shop for even better outcome.
sloride
ohio
2016 GT
That’s why I’m building mine. If it blows up. Guess I messed up and don’t have to go through “he said she said”. If it stays together I’ve saved almost $3,000
Jackson1320
California
Jaxson
2015 mustang gt
Aluminator is a stock coyote with rods and pistons. Yes it should be just as dependable as a stock coyote. The pistons and cylinders will wear slightly sooner do to the extra piston to wall clearance but still 100,000 miles if cared for. I would get a brand new short block and install Mahle drop in pistons the same as the aluminator. It will cost you around $3500
