Returnless Fuel System Options & Threads
Blackedoutdreams
Ben
2016 Gt/Cs
Good info. The arcane system looks interesting to me as it looks like they will assemble the kit and probably can help me pick a system for my goals. I’ll probably reach out and see what I need
I have also have the arcane/juggernaut fuel system in my car. If I remember correctly, it's their stage 3 deadhead kit which is return style with factory rails. It's pretty nice kit overall imo
LOL WUT
Illinois
19 GT
Stage 3 is a return system. If you have a deadhead, it’s stage 1 or 2.
Blackedoutdreams
Ben
2016 Gt/Cs
My kit came with an external regulator to run a return line. I'm not using the regulator that comes on radium hat.
LOL WUT
Illinois
19 GT
A deadhead system doesn’t have a return line. So you do have the stage 3 system 👍.
engineermike
La
2018 GTPP A10
Is this gen3 or gen2? And stock fuel lines only the pump, injectors, and boost a pump?
Gen3, stock lines, only dw400, 22v bap, and injectors.
Speaking of lines, check out the power that gt500’s are making on e85 deadhead on the stock fuel line. The fuel line is the same diameter as gen3 (not sure about gen2). I’m talking 900+ rwhp and they are less efficient due to low compression. And, using turbos adds another 10% or so efficiency (less fuel required for the power level).
Another issue is tuning. Lund won’t touch e85 boost without return and I’m not confident enough with my tuning to do it unless I can get a Lund 91 boost tune and convert it to e85.
Also correct, most tuners won’t touch e85 on a single pump deadhead system. It’s a shame because a dw400 and bap will support e85 and boost on most sc systems on stock injectors even with mild increases in boost.
tdstuart
tdstuart
Arizona
Triston
2015 Mustang Gt Premium
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
LOL WUT
Illinois
19 GT
p
Don't see why not. The Demon 170 uses E85 with a returnless fuel system.
Because they are stubborn.
However, they have no way to really tell if you have a return system. They tune for the injector size and pressure, not pump size or fuel line size. I could have tossed in a DW400 boosted it and told them I had return system XYZ if I wanted. So long as pressures look good and injector data is correct, they have little way of knowing if your system is a return or not.
engineermike
La
2018 GTPP A10
Any info for gen2? I assume less as I don’t have direct injection
The lift pump and feed line has to supply all the fuel in either case. Both need injector upgrades, though the gen2 obviously needs bigger port injectors..
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Ahhhh ... one of those " it's my way or the highway " things. Gotcha.
Another thing I found interesting was they keep talking about fuel getting hot.
According to "Study on the Effect of Fuel Temperature on Gasoline Engine Performance and Emissions" by S. Yilmaz and M. Ozener (Energy Conversion and Management, 2016).
The gasoline temps will be around 1/2 engine operating temps by the time it reaches the injector. Assuming the fuel in constantly flowing.
Found another interesting study on fuel tank temps here:
https://www.ncbi.nlm.nih.gov/pmc/ar...text=For most vehicles, there is,20 and 35 °C.
One of the reason they want return system is for cooler fuel, but I think that's a non-issue for any modern fuel injected vehicle.
A carbed engine running @ 6psi fuel pressure, sure. Here's the reason.
At 6 psi: Gasoline begins to vaporize at around -20°C (-4°F), with a boiling point of approximately 80°C (176°F).
At 60 psi: Gasoline begins to vaporize at around 20°C (68°F), with a boiling point of approximately 150°C (302°F).
Again, a non-issue IMO. But then again I ain't no engineer haha.
Midwestracer
Fayetville Arkansas
chris
2018 mustang gt whipple
with a gen 3 DI and 1050x and a 3rd gen gt500 fuel pumps jms BAP ive been bottom 9s@150+
3.0 whipple gt350 fuel line on E85
engineermike
La
2018 GTPP A10
Awesome. I’m also running a 3.0 griptec, 6 rib. Gt500 bucket. I kept the stock ps module and modified the bucket Venturi though, plus added a filter. I’m running dual FPDM but no bap. It’s holding 80 psi pressure at max flow and just barely touching 100% duty cycle.
