Replaced Voodoo Engine
  • Total voters
    91
Frank.Herbst
Denver, CO
Frank
2019 GT350
Got it. I am happy to pay for the part at that price if it makes a difference. Can you post a link to the thread that discusses this. I’d just like to be informed when I talk to the dealer.
I posted pictures that I still have copies of. I had Ford change the plate in my 17 GT350.
Frank.Herbst
Denver, CO
Frank
2019 GT350
Does anyone have the updated part number for the new cylinder block plate?
This was the newest part when the replaced mine. I would check with a Ford parts person to make sure they have not updated this one. This part solved the rattle noise I had at certain RPMs.
Lorne34
Project Hidalgo
Wisconsin
Lorne
2019 GT350
It has been almost two weeks and the dealer just told me that the engine has been ordered but is saying it will take 4-6 weeks to arrive. That seems like a ridiculously long time to ship an engine across the country. Dealer and the service rep don’t seem to really be making me a priority. Nor are they doing much to move this process through quickly. I haven’t even been offered a loaner vehicle. Does anybody have any suggestions on how to light a fire under their butts? Should I try and reach Ford Performance myself? Any help would be appreciated.
It seems your mileage will vary with each dealership. No consistency whatsoever. You could reach out to Ford Performance- normally they assign you a case manager or make your complaints known to the GM. I know a guy on You Tube (rated R cars) had to continually call Ford Corporate to get things moving.
Is this your daily driver? If it is they should have offered a loaner vehicle or you could look for reimbursement on a rental car.
jvandy50
H3249
AR
jason
23 Bronco, 18 ZL1-1LE
That's what I was told also, but it came in a little sooner. Apparently sometimes they don't just have some voodoos sitting around...luck of the draw on when yours goes.
Trying to light a fire under the dealer's ass just got me labeled as 'picky' (they finished my car and just didn't call, gave it back with a CEL twice). Because wanting a splitter that doesn't fall off and a properly working engine is just a little high maintenance these days I suppose.
Idk if it's a good idea or not, but you could always mention, depending on the state, over 30 days in the shop can lemon the car.
agentscreech
Wa
2017 Lightning Blue GT350
This was about the same time it took for mine. They had it for a week or 2, then got the approval and engine shipped. Then they said it was another 3 weeks. Had a loaner Edge the whole time.
Frank.Herbst
Denver, CO
Frank
2019 GT350
Ok so my 2017 GT350R was given to the dealer on January 20 and was ready for pick up with a new engine on February 21. So one month for the whole thing. I was surprised that once the new engine was received, the new engine was installed in just a couple of days. I thought the shop work would take longer. So it seems that the vast majority of the time for this process is just getting the engine shipped to the dealer. Ford Performance makes the dealer jump through a few hoops before they order the engine. Check for ECU meddling etc. As I did none of that, I had no problem and the engine was ordered about a week after the dealer got the car. About 2 ½ weeks from the time the engine was ordered until it reached the dealer. I drove it home from the dealer just cruising and not winding out the engine as I want to be careful to break in the new engine properly. The car was absolutely filthy having been left outside for a month to let the dirt and dew bake into the exterior. It was so bad, I told them to leave it alone so they wouldn’t jack up the paint washing it was some dirty rags. Spent about 4 hours washing and cleaning it up. Looks like I will need to do a little correction to get it back to the condition I like though. In general the dealer was not very good with communication and I only heard from them a couple times in the whole process. I never heard from Ford Performance. They never even offered me a loaner. Fortunately I have an extra car so I used that for the month. I hope the work was good and I don’t have any more issues. The time it took for the replacement was reasonable I think but the process was a little unsatisfying due to the lack of communication. Now I need to get one of my carbon wheels replaced as it looks like someone on the assembly line completely missed the spacer retaining clips that hold the spacer on the front wheel.
Best of luck, let us know if you think the new engine is any different. My 19 seems to run a little different than my 17. But my 17 was not an R.
morepowr
Columbus, OH
Tim
2017 GT350
New here with a 2017 GT350 w 17,540 mi. Mentioned high oil consumption to dealer and they put me on oil consumption test. Took it back just 50 shy of 1000 miles and got and call the next day that a new engine has been ordered. Dealer is being mum about how much consumed or any details. I know I used 10 its in 5 k miles prior to oil consumption test. AC issues as well. If I can find out more details I will post.
Hack
Minneapolis
Mustang, Challenger
Glad you got a new engine - my advice is to try to avoid cruising with a new engine if you want good ring seal.
DCShelby
DC
Robert
Yes, do not do steady speed cruises. I would also go look at the engine bay and make sure all hose clamps are tight and positioned. In my engine replacement, I had to move two hose clamps up a bit. Least with mine, they did keep it inside and i had no issues of being dirty or getting scuffed. My new motor is one year and one month old and uses little oil after 13K miles placed on it. I did have to get the AC compressor replaced and they rear cylinder block plate replaced since then, which should have been done when the engine was replaced.
Lurker_350
TX
2016 GT350 - Tech
Ensure that they replace the AC compressor bolts. They are single use and there are a few instances of re-used bolts failing - leading to engine replacement. It would suck to get your engine replaced, they re-use the bolts on the new engine and break them in the block, leading to another new engine. I think @EF300 may have experienced this?
Ron Swanson
AZ
BMW & Lexus
Getting the itch again to buy one of these... Is the inherent issue that's causing blown engines still a mystery?
Thx!
morepowr
Columbus, OH
Tim
2017 GT350
Update. Got the replacement engine which is an '19 "R". Had it about 3 weeks and 340 mi and on way to work it just shuttered real hard and sputtered. I was able to coast into a parking lot and have it towed in. Dealer said motor seized up and towed it to dealer that put engine in. The dealer that installed the motor says a piston hit spark plug. I am thinking a wrist pin came loose or maybe a faulty injector caused high compression that detonated the spark plug. With the virus situation the dealer is saying they have a skeleton crew and may be a while before they can replace motor. They have offered a loaner car sos far.
johnny1
I'm really sorry to here this happening to you. Wish Ford could get these engines right. If doesn't go bad no matter how driven, the Voodoo is a very powerful engine and the GT 350 really fun to drive. Hope you don't have to wait to long to get engine again replaced and that its all good from then on.
